tci conveter missing bolt and causing vibrations
Old 05-30-2007, 02:57 PM
pugads650's Avatar
Default tci conveter missing bolt and causing vibrations
hello a couple weeks back i reistalled my tci 3500 stall converter back into my car and i lost one of the bolts and ive been driving it with just 2 bolts and im starting to get a slight vibration does anybody know what size bolts this converter takes i would greatly appreciate it thanks.
it is the tci 3500 street fighter for a lt1
jonathan
Old 05-30-2007, 08:39 PM
smoknta's Avatar
I would also like to know what size they are. I think they are 3/8"x16x5/8" , but I would like someone to confirm this.
Old 05-30-2007, 08:48 PM
LS1Tech Sponsor
performabuilt's Avatar
I dont know the size but i do know it could not only cause a vibration but also damage the flexplate and or converter/pump
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-30-2007, 08:55 PM
DrkPhx's Avatar
First, I wouldn't drive the car with only 2 bolts installed. For the exact bolt size try contacting user Kevin Winstead. He works for TCI and is very helpful. Or you can remove one of the bolts, take it to a hardware store to match the thread and length.
Old 06-02-2007, 09:44 PM
Predator T/A's Avatar
make sure its a grade 8 bolt or stronger....i am surprised that the flywheel isnt making a knocking sound becuase it is flexing there
Old 06-02-2007, 09:49 PM
pugads650's Avatar
it was a 7x16x20x1
Old 06-02-2007, 09:53 PM
LS1Tech Sponsor
Gald you got it fixed I wasnt sure what to tell you there since our converters are all set up to use the OEM bolts
__________________
Call 888-744-6542
Old 06-02-2007, 10:55 PM
pugads650's Avatar
vibration totally gone and the converter seem to be running better both 2 bolts were very tight but i do feel a diffrence.
Old 06-02-2007, 10:56 PM
LS1Tech Sponsor
Just glad you got it fixed without any serious damage accurring
__________________
Call 888-744-6542
