is my flywheel(flexplate) warped?
a guy at a shop said that the pump in my transmission might have broke because the flywheel might be warped
i had someone crank it over and i watched the flywheel as it turned. it barely wobbles, just a tiny tiny tiny bit
do i need a new flywheel?
also, this flywheel is brand new, came off of my brothers ls2 crate engine
I'm having the same problem, and asTXJeepTJ said, my flexplate is barely wobbling. Unfortunately, this is now the second pump assembly that I am on, and I don't want there to be a third. I'm replacing my flexplate as well
I had a nice TCI flexplate that was warped bad and lucily I could hear it while cranking the new engine. It sounded like the crank was scraping ON the crankscraper so we pulled the pan...looked good, then we spun the flexplate and it was visibly warped. Swapped to a JW Wheel and all was well... Cheapest part of the driveline I think...get a good one!
