WOT 1-2 shift
WOT 1-2 shift
I can make 2 or 3 run's (1/4 mile) The trans will shift fine into 2nd,When I get to about the 4th run it hits the rev limiter.They are not back to back run's,The trans fluid is about 140* to 150* each run.What would cause this,What should I check.All the parts are pretty new,Few months old...................Paul
Originally Posted by performabuilt
I would check the servo and servo bore along with the hole the pin slides into you may have wear there, I would also look over the servo seals. What servo are you using ?
