is my trany gone?
Old 07-22-2007, 06:39 PM
bwillbblown's Avatar
Default is my trany gone?
i have a 99 silverado and 2nd gear,overdrive and reverse is gone. should there be any codes.
Old 07-22-2007, 06:47 PM
LS1Tech Sponsor
performabuilt's Avatar
Sounds like you have a broken or stripped sun sunshell a common weak point. And no there may not be any code. But you do have a mechanical issue POWER flows through the sun shell for 2nd,4th and REVERSE Trans will need to be gone through or replaced
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 07-22-2007, 06:58 PM
whats is a around about price to repair this
Old 07-22-2007, 07:45 PM
LS1Tech Sponsor
Thats hard to say most shops wont do a repair like that for less than a rebuild because of warranty issues. I mean they do have to disassemble the trans mostly just to replace that peice
__________________
Call 888-744-6542
Old 07-22-2007, 08:00 PM
Gilbert@Ace Racing's Avatar
Depending on your needs you are in the $1500 - $2500 range.
Unfortunately there is more to it than just a shell replacement.
g
Old 07-22-2007, 09:30 PM
GOaT Cheese's Avatar
I have actually just thrown in a new sun shell before, if it broke clean and wasn't driven afterwards, you might get away with it.
Old 07-22-2007, 10:01 PM
It can be done... suppose it depends on your expectations.
g
Old 07-22-2007, 10:33 PM
FLT
FLT's Avatar
Make sure to upgrade to the beast shell when you have it done. We have a modified version of this shell that uses a bearing and a modified low roller race. Nice piece IMO. Vince
