tranny shifting at 6300 rpm!!!
Old 07-24-2007, 05:56 PM
boola1341's Avatar
Default tranny shifting at 6300 rpm!!!
Does a stock a4 in a 02 Z28 suppose to shift at 6300 rpm from 2nd to 3rd in drive . From first to 2nd it shifts right a 6000 (doing 60 mph in first). Is better for me to shift the gears myself from 1st to 2nd to drive???
Old 07-24-2007, 06:07 PM
LS1Tech Sponsor
performabuilt's Avatar
You may need your tuning ajusted as far as shift ponts as long as the 2-3 shift feels good when it happens , Are you hitting the rev limiter or something at the 2-3 shift?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 07-24-2007, 06:22 PM
boola1341's Avatar
it's not hitting the rev limiter. A handheld programmer like the predator should take care of that problem right......should be shifting a 6000 rpm in every gear? Car has 78000 miles on it. Is it time to get it freshened up?
Old 07-24-2007, 06:54 PM
LS1Tech Sponsor
Well youcould have a little excessive 3-4 clutch clearance but it does take longer from comand to actual gear change on the 2-3 shift theres just more happening than with the 1-2 and yes that tuner should be able to handle it
__________________
Call 888-744-6542
