Automatic Shift Knob
Old 08-03-2007, 10:50 AM
ealucero1's Avatar
Default Automatic Shift ****
How Do You Take The Automatic Shift ****, I Have A 2000 Ss Camaro.
Old 08-03-2007, 11:02 AM
CaMaRo67RS355's Avatar
pry the button out of the top of the shifter. then i think the leather handle part pulls up then you should be able to look and see which way to go from there
Old 08-03-2007, 11:26 AM
camarolvr69's Avatar
^NO.
There is a staple in the middle of the front part of the shifter.
Pull that out and the **** comes straight up.
Old 08-03-2007, 12:27 PM
thats what it shows in a corvette owners manual for the 02 corvettes so i figured it was the same
Old 08-03-2007, 04:24 PM
2001NBMZ28's Avatar
Yeah the staple is on the front side of the shifter, remove and pull straight up. Easier to see/get to if you turn the key on and put it in first gear.
