4L60e drain plug
Old 08-21-2007, 02:50 PM
cptncdy's Avatar
Default 4L60e drain plug
does anybody know what size it is? im planning on installing a trans temp gauge this weekend and want to put the temp sender in place of the drain plug.
Old 08-21-2007, 11:29 PM
cptncdy's Avatar
bump...
Old 08-22-2007, 12:52 AM
Sunset'01Z's Avatar
stock tranny pans dont have drain plugs.
Old 08-22-2007, 05:43 AM
usd2sing's Avatar
if u are using a deeper pan from a truck trans the drain plug is a 15mm.
warning. the head of the drain plug is soft, easily damaged and extremely tight (at least mine was)
i just picked up a replacement from the dealership for $7.
it also uses a deeper/taller filter.
$13 at the zone.
where as the standard shallow pan filter is only $9.
Old 08-22-2007, 06:42 AM
01Z28M6's Avatar
Can I add something since your question has already been answered - knowing how I don't like to get answers to question that weren't asked .
To get the most correct (and highest) temperature reading you should put the sensor in the line going to the radiator (or cooler) that is first out from the converter; also referred to as the hot side. There are several good threads about this here and other fine fbody boards. Good luck.
Old 08-22-2007, 03:21 PM
cptncdy's Avatar
thanks guys..i thought there was a drain plug, but never did actually look. i will probably just put it in the line going to the radiator like 01Z28M6 suggested.
Quick Reply: 4L60e drain plug
