blown trany ?? help
Old 08-26-2007, 08:21 PM
transam45's Avatar
Exclamation blown trany ?? help
1ST PROBLEM
(I was havening problems with my torque converter bolts coming lose i thought it was a spun bearing so i pulled motor found out it was only the flex plate and bolts coming loose that made it have the knocking sound. so i fixed the flex plate and put thread lock on the bolts then put the motor back in then.)
AFTER MOTOR WAS PUT BACK IN
-After i put the motor back in it the car was driving fine all day until later that night, i was driving it when it started acting funny, so i pulled over and it died, i checked the oil and could not get a good reading so i put about 2 1/2 quarts in the car,
-After that i tried 2 crank it, but it kept dieing so i put it in neutral and revved it up so it would not die again, then i dropped it in gear and it started knocking horribly from the transmission/back off motor area.
-Then white smoke started poring out from under my car, and the check engine light started flashing, after that it sounded like some bolts came loose followed by a big black cloud of smoke that came out from under my car and everything turned off no power.
-I tried to drop it to neutral and start it,but only made a grinding noise so i tried to give it gas like before but nothing happed,
-so i coasted to a stop and i checked fluids i still had oil, but it was a little bit over full from the 2 1/2 quarts i put in it earlier, but there was no trany fluid.
-i think i burned up my trany.
-Any 1 have any ideas. ????
-Now when i try to crank it just makes a grinding sound i think the flex plate might be broken to.
Old 08-26-2007, 09:32 PM
LS1Tech Sponsor
performabuilt's Avatar
Well I can only agree from the description it does sound like the trans is fried. Sorry. Let me know if we can be of any help .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 08-26-2007, 09:46 PM
transam45's Avatar
you think this might have hurt the motor even threw all this the motor still felt strong
Old 08-26-2007, 09:57 PM
trans am1's Avatar
if you are looking for a good a4 tranny i have never heard a bad thing about any of the trans sponsers from this site i just bought my level 2 from preformabuilt
Old 08-27-2007, 09:11 PM
transam45's Avatar
any 1 think that this might have effected my motor ?
Old 08-27-2007, 09:30 PM
LS1Tech Sponsor
well its not likley the trans hurt your engine but thats not to say you couldnt have problems with both
__________________
Call 888-744-6542
Old 08-28-2007, 11:57 AM
transam45's Avatar
from what i discribe what does it sound like happend to you ? i dont know much about trannys my friend that was following me said that some of the white smoke was comeing out my exhuast could this be from over filling the oil ? or do i have a serius problem with the motor ?
Old 09-01-2007, 01:22 AM
transam45's Avatar
Old 09-01-2007, 09:46 PM
LS1Tech Sponsor
will the engine start?
__________________
Call 888-744-6542
Old 09-02-2007, 04:39 PM
transam45's Avatar
no i think the flex plate or starter is broken so it just grinds when i try to start it
i was thinking if the torque converter bolts were backing out that could of set the torque converter off balance causing it to brake the front seal making all my tranny fluid come out and possible hitting the exhaust making all that smoke ?
