TH 400 flex plate??? Please Help.
Let me bring you up to speed first of all. I am doing a t56 to 400 swap. I bought a flexplate from a guy on here and I went to install it, and I notice that the dowel on the crank does not fit in the holes on the flex plate. The flex plate hole where the dowel goes is threaded
Also it is a Callies crank that it is being bolted to , not a stock ls1 crank. Does that make a difference? Does the flex plate not need a dowel? Also do you think I need a different flex plate? It has a spacer for the 400.
Originally Posted by JL ws-6
what kind of flexplate is it? if it's not an sfi apporved one, I'd suggest getting one. Hughes makes a nice one that's not too expensive and works good... I've had one in my car for a year now and it's been fine.
