not again...:(
Old 10-08-2007, 07:45 PM
one fast ss's Avatar
Default not again...:(
k guys...i duno whats going on with my truck...i just reinstalled a reactor flexplate and all arp bolts with a percisions converter.....i had the truck for 3 days...one the 3rd day i hit it off the line...went about 70-80ft and there was a big boom...its the long wekeend here so i havent looked at it yet. i have no reverse...drive..or park. last time the bolts broke i had park. also the fluid is still going down when the engine is running so i duno what it could be this time. where is the parking pin in the ss drivetrain?
also i was reading on the net that the ss slipts the power 38 front 62 rear...so i could be running more power then seen on the dyno since we took the front shft out to get it on the 2 wheel dyno.
i was just wondering if you guys have anythoughts on whats wrong...
Old 10-08-2007, 07:49 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
your transfer case is chain driven isn't it?
Maybe you blew the T-case? Just a an idea.
Old 10-08-2007, 08:04 PM
i believe so..yes
Old 10-08-2007, 08:10 PM
if the t-case blew would i still have park?
Old 10-08-2007, 09:28 PM
LS1Tech Sponsor
performabuilt's Avatar
You could have anything from a stripped planet. Broken output shaft. or transfer case to not have park , I would pull the xfercase and the pan and inspect.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 10-09-2007, 10:40 AM
LS1TECH Sponsor
ALLBOTTLE's Avatar
you should just start taking it apart on piece at a time till you find out what took a crap.
Old 10-09-2007, 11:04 AM
LS1Tech Sponsor
hellbents10's Avatar
I have broke quite a few output shafts on those, never a t-case though.
