Strange Vibration
Old 10-15-2007, 06:44 PM
Joker98's Avatar
Default Strange Vibration
Whats up guys? I seem to have a vibration that comes and go's day to day. One day the car drives mint and the next the vibration is pretty bad. It seems to be mostly on accecleration but on the expessway(60-70mph) the vibration seems to pulse while driving! I put the car on the lift and noticed that the yoke at the tailshaft seems to have a ton of play in it. I know there is supposed to be alittle but this seems excessive!! Has anybody ever seen this happen? What kind of repair am I lookin at here?
Old 10-15-2007, 07:19 PM
Gilbert@Ace Racing's Avatar
Not a big job at all. The bushing inside the tailhousing has worn. Is there a leak there as well?
Either way I suggest the following.... have the driveshaft balanced, replace the tailhousing bushing and related seals. Then drive it and see what happens.
g
Old 10-15-2007, 07:27 PM
Joker98's Avatar
yeah i did notice a leak there. So what is involved in replacing the bushing? Where do I get what i need? Would that be causing my vibration?? Thanks for your help
Old 10-15-2007, 07:29 PM
The vibration is a harmonic that is setup at a given rotational speed. The driveshaft being out of balance could have caused that condition, no way to know until it is properly checked / balanced by a driveshaft shop.
Take the taihousing off, take it to a local tranny shop and they will knock a new bushing in for a few bucks, have them install a new seal also.
g
Old 10-15-2007, 07:38 PM
Joker98's Avatar
Cool..will do. Thanks for your help man really appreciate it.
Old 10-15-2007, 10:18 PM
Well you're not out of the woods yet... but I think that's a good start.
Get back to us after those repairs and tell us if that took care of it or not.
Oh, be sure to check the transmission and motor mounts while you are under there. Sagging mounts can change the pinion angle slightly... it's a long shot but worth the time it takes to check 'em.
g
