Help with Fittings?
Help with Transmission Cooler Fittings?
I have a 05 GTO with the 4L65E Trans, I am looking at adding a Trans Cooler, and a Stall. I want to know if someone could tell me what fitting size/thread comes out of the Trans, So I can replace them with AN Lines, and fittings.
Hopefully the Automatic Trans Gods will answer?
Custm2500's #1 Fan
Here's my swap thread...
Hope this helps. Its installed in my truck but the principle is the same.
https://ls1tech.com/forums/showthrea...t=#post6685967
