4L60E fluid leaking
4L60E fluid leaking
Needs some help guys.......I swapped a 99 LS1 and 4L60E into my 57 chevy and used the original 'F' body trans yoke. When I lift the front of my car up about 2 ft for working under it, I begin to get trany fluid dripping from a small hole in the center of the yoke behind the u joint. It appears that fluid is flowing through the splines and coming out that tiny hole.! Is that hole supposed to be there and if so how do ya keep the red stuff in..!!??
Thanx for any help in advance.!! DK
Thanx guys....I will drop the driveshaft and dab that baby wiith a little Hi temp RTV and call it day..!!! I knew someone would come through on this forum......an awesome group of gearheads..!!
Thanx Again DK
Thanx Again DK
