what cooler is everyone using on 4l60e
Old 12-30-2007, 06:14 PM
ls1pwrdss's Avatar
Default what cooler is everyone using on 4l60e
im looking to get a cooler with braided lines and an fittings
any sugesstions.
Old 12-30-2007, 06:18 PM
87gnx's Avatar
B&M 24K here. I just use the quick connect fittings.
Old 12-30-2007, 06:26 PM
lj04's Avatar
Do you have any pictures of the install?
Old 12-30-2007, 10:34 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Perma Cool unit with a fan on it.
Old 12-30-2007, 10:59 PM
Top Fuel's Avatar
B&M 70266 here. I use it with my th350 and 8" verter. summertime highway temps are in the 130 range. might be slight overkill with lock up and OD, but you cant really complain about your trans fluid being too cool
Steve
Old 12-31-2007, 12:54 PM
radz282003's Avatar
I have two 24K B&Ms with clamps on the hoses. I have them mounted where the washer reservoir used to be (I moved it, well replaced it, under the drivers side headlight.) My car rarely sees over 180* after 1320 runs.
Old 12-31-2007, 03:44 PM
jmm98LS1's Avatar
I had a B&M 24k mounted in front of the a/c condenser, right in front of the driver's side fan. I ran it after the stock cooler and never saw the north side of 175*F with a 3600 stall.
Old 12-31-2007, 04:30 PM
zer0psi's Avatar
I have the 24K too, with a 3600-3800 Vig.
Old 12-31-2007, 04:39 PM
JScamaro's Avatar
I have a Hayden Rapid Cool 30k unit that Yank recommended for my Yank SS3600.
