trans cooler
trans cooler
if i put a trans cooler in my vette then on average how much lower will the tranny run in temperature i have a 3500 stall and it gets real hott reall fast
My B&M 2800 cooler dropped my temps 20 - 25 degrees under most conditions. I know this because I installed a SW trans temp gauge just before hooking up the cooler.
um but 150 sets off all of my cars sensors and ***** my car up on top of that my transmission ***** stuff up at 150 it keeps makin my second to third go out and it caused my isf switch to go out
LS1TECH & Trucks Sponsor
With a 3600 stall I dropped 20-25 degrees, and with the addition of a 2nd cooler I'm down to about 35 less than with just the stock radiator cooler. With that stall you need to get a good cooler in there, heat is your tranny's worst enemy.
How are you reading that 150?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
i have a corvette not a bird or a camaro it reads my tranny temp to me electronically in my dash o hey if u knwo anything bout my other post would u be able to help me ther i posted in the maintanence and its three enging codes will u check it out man
man serisously that car is the devil i am way over my head i have about 11000 in repairs to my car already i could have bought half the cars in this ls1 group for just the amount that i have in repairs in my car im super pissed
ok so i screwed up lol i have no idea what i was thinkin i put 150 but i meant 250 my tranny gets all the way to 250 degrees so if i put the tranny cooler on it then am i still going to hit 250
According to what is written on my B&M cooler box, your temperatures are just below the threshold where the fluid mutates into varnish. This is the point where component failure is immanent.
I figured it was a typo, 150 is insane with a stall and no cooler. It sounds low for not having a stall Put a good cooler in there ASAP! How long have you been running it like this?
__________________
umm 1600 miles or so but mostly with cold weather and its only got to 250 once i usually dont drive far and since i put in the stalli havent raced anybody so hope it aint messed up to bad i have to put alot more stuff in my car before the cooler though i still dont knwo why it wont idle
It shouldnt get to 250 on the highway even with a stall cause it should already be locked up...once its locked theres no slip thus no heat created.... are u sure it locking on the highway?
If it's the manifold:
Take off the intake & MAF, fuel rails & injectors, unplug the wire harnesses by the coilpacks, then unfasten the 8bolts on the sides of the manifold, slip the manifold out and visually inspect the gaskets.
yup the intake manifold gasket i looked it up and all 8 of them come together and its only 25 bucks so i guess i will take it apart and fix that **** for the price i might as well lol
