4L80E TCC limit Valve in pump question (FLT),others help
What would the effect be if the TCC limit Valve spring was removed and a spacer installed to limit the valve movement in the pump..
I removed the valve from the pump and there was a "made" spacer where the spring goes in the pump TCC limit valve. It was not a spacer from a kit it is a piece of 3/8 fuel line cut 3/4 of an inch and slid over the shaft of the valve.
I just want to know what this "mod" will do. Should I get a spring and install it?
Thanks Tom
Thanks Tom
