LT1 m6 clutch bleed
LT1 m6 clutch bleed
is it different than bleeding the ls1 m6 clutch? i have the service manual and all its basically telling me to do it un bolt the master to the end of the threads and push on the slave. i just installed a new master and slave, bench bled both and the little plastic clips on the slave wont even break. is there a bleeder screw on the lt1 clutch system? if there is do u have pics?
