4L80E 2 or 4 wheel drive?
Can a 4X4 4l80e be used in a rear wheel drive vehicle? Can the "transfer case" (proper term??) be unbolted from the tranny case to be used in a car?
Do all 6.0L engines (truck) come with 4l80e's or do some come with 4l60e's?
Doing a little research here -would like to get a truck 6.0engine/transmission/harnes to drop in my 87 Monte Carlo if possible. Need to know if that's possible or should I use a 4l60e from a car instead..
TIA
Dean
TIA
Dean
In you want to use a 4x4 trans in a car you need to remove the transfer case. Then the trans needs to be completley disassembled and have a 4x2 output shaft and tail housing installed. You might have problems finding just the shaft and housing.
I would assume a 6.0 truck would have a 4L80E, a lot of 4.8's have them.
As far as a 4L60E vs 4L80E it depends on what you want to make out of the car. Power and weight will determine the best trans selection.
