Vig 3600, trans cooler : Do I NEED a shift kit??
Old 04-28-2008, 01:27 PM
Kenny H's Avatar
Default Vig 3600, trans cooler : Do I NEED a shift kit??
Its a bolt-on '02 Z28 w/ 3.23s and I'm about to order a Vig 3600 and a trans cooler. Do I absolutely need a shift kit? If it basically does nothing (I will be getting the car tuned) than I don't want to waste the money. Thoughts??
Old 04-28-2008, 01:33 PM
ta_06374's Avatar
No you dont.
Old 04-28-2008, 03:19 PM
02NBMFormula's Avatar
read the sticky
Old 04-28-2008, 03:22 PM
BJSS25's Avatar
Kenny they shifts would feel firmer with a shift kit than changing the line pressure in the tune. I would go for the shift kit, it also will help the trans live longer.
Old 04-28-2008, 03:42 PM
TXZ28LS1's Avatar
yeah u dont really need a shift kit as much as you would a tranny cooler!!
Old 04-28-2008, 05:11 PM
01ssreda4's Avatar
called a bunch of local shops and they didn't even wanna install a shift kit in a 100K tranny without rebuilding it
Old 04-29-2008, 11:42 AM
omcar's Avatar
if you do decide to install a hift kit (i did and I'm glad) you may need to delete your torque mgt to have it shift right..
Old 05-03-2008, 08:57 PM
armyracer11's Avatar
you can get the tranny pressure turn up with the tune and that should be just fine for a bolton car
