Running with stock tranny?
Old 05-08-2008, 06:22 PM
coreygalyk13's Avatar
Default Running with stock tranny?
ok i have a 97 z28 with a few mods like lt4 cam and heads with P&P intake, moroso intake, headers, 3.73's, slp lm2, tune which i think they had the shift point raised and firmed it up and a few other small thing here and there and i was wondering if you guys think it would be ok to run my car at the track the transmission is completely stock and stock tq converter? let me know what you think thanks.....
Old 05-08-2008, 06:34 PM
LS1Tech Sponsor
performabuilt's Avatar
One can never say when a trans might die but I see no reason why you shouldn't theres risk every time you floor the car at a stop light or pass someone. I would if thats what you want to do.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-08-2008, 06:41 PM
when i get into it i dont let it rev all the way out i usually let up about 5 grand because im worried about the tranny
Old 05-08-2008, 11:14 PM
Self-Admitted Scammer
ls2pontiac's Avatar
i used to rev my 4L65 to 6500 every day for 7 months and it blew the pump and the 3-4 clutch out. trans guy at the dealer said the low roller had some heavy damage to it as well. lol. 11k miles on the trans is all it lasted. did a ton of burnouts too, i mean 20-30 second ones, without a trans cooler. so I'd say they can handle a really good amount of abuse, provided you are starting out with a fresh trans. if its old i would drive it easy and wait until it goes b/c im sure it will.
Old 05-09-2008, 07:48 AM
its got 80k and was just flushed
Old 05-09-2008, 10:07 AM
ICRAZY6's Avatar
You'll be fine to beat on it. Do you have a cooler? Excessive heat and extremely high rev's kill the trans quick.
Old 05-09-2008, 10:14 AM
jeffbab's Avatar
What's a normal temp for our trannies to operate at?
I have seen mine go as high as 100 degress C one time. But most of the time it is less than 80 degrees C.
Old 05-09-2008, 10:23 AM
ya i do have a tranny cooler on it but thats all done to help it
Old 05-09-2008, 06:15 PM
01ssreda4's Avatar
mine stays 150 on the highway and i have seen 180 idling for extended periods.
