Does a stall change with more power?
I have a new box and stall fitted up and am already concerned that the stall speed is a little high. I have a head and cam combo going on so want to know if the stall speed will rise as the power does or will that actually make it lock harder and at lower revs
It is a fact that if you take a converter that was designed to stall at 3,000 rpm in a stock application and you install it in a 500 h/p application it will stall much higher. That's just an example.
Torque Converters must be matched for to the given powertrain combination.
g
g
I have a new stall with good bearings furnace brazing throughout etc, will I damage it by upping the power and putting it into a different rpm range? I am thinking of just seeing how much it goes to with the extra power and if works for power just leaving it.
I don't want to damage it, that is my concern
The builder said he didn't want to go for a heavy assembly because my car at best will only make 340hp 550ft/lb
at the wheels and is a torque. It's an L67 (V6).
I'm told the converter needs revs to be at its' best but I'm making most of my power below 4000rpm and after that it levels out.
It's a daily driver by the way and weighs 3900lb
Type of convertor? I'm not very knowledgeble on them so can't really give details. Torrington bearings, no billet stuff AFAIK, lock up clutch, apparently it's highly reinforced.
Chris
I am a little confused. You are putting this converter in a different car or just adding a little more power to your current setup? If you are just changing cam or something I would think you will be fine, but with out knowing anything about the converter it is impossible to tell how much HP it can take.
Chris
Chris
After the head and cam go on it will only jump about 100hp anyways so time will tell.
Chris it would be good if someone started a thread about how performance convertoers work and the relevance of the aftermarket parts that go into them.
