tranny pan w/temp hole
Where can I get a tranny pan that has the temp hole. also where can i find the temp gauge?
I did the search for tranny pan with temp hole but nothing pertaining to me came up.
You dont put the trans temp sending unit in the pan, you put it in the side of the trans its self. If you look at it on the drivers side about half way up there a square looking plug. You can remove that and install it there. Or you can buy and earls fittings and place it in line with the trans cooler lines.
We place Trans Temp Sensor in the pan all the time. The reason is I want to know what the temp of the sump fluid is. The sump fluid is the fluid that is being picked up by the pump and being circulated throughout the unit and converter.
As far as the pan having a hole for the sensor... you won't find one. All you need to do is buy the gauge and then drill the hole that is recommended as per the manufacturer. We do it frequently.
g
g
