stall and rear question.
hey guys im going to be geting a stall and a cooler soon and had a question about my rear end. i dident know if i should of posted this in the gears and axles section so if i put it in the wrong spot mods please move.
i want to go with a 3200-3400 stall ans im going to get a cooler to go with it
im unshure about the brand im going with so ill take some sugestions on that.
how much of a stall will break a 10 bolt? my trans is stock with about 90% of tm removed and i think my line pr is bumped up a little.
i run nitto drags in the rear and i have a edelbrock adj ta,lca's with brackets, hypercoil springs/bilstien shocks. the car hooks good at the track and i dont really get any axle hop and my best 60ft so far is 1.9 flat.
let me know guys.
let me know guys.
its prolly more the actual traction then of the stall, as to whether you break anything. although mine breaks the tires loose pretty easy now the the verter is in. i would hate to see what part of my driveline explodes with some sticky tires.
what would be the best cooler to go with? i dont want to have leaks and drips and it be reliable. the owner of the tranny shop specializes in perfomance trannys and is a friend of mine so he is going to charge me 85 bucks to put the converter in then maybe a little more for the cooler.
ill take my car to the dyno to get it retuned for the stall.
