Installed Transgo Stage II shiftkit, now wont shift into 3rd in WOT.
I had a shift kit installed into my 4l80e and it wont shift into 3rd at WOT, it hits the rev limiter. I am going to try lower the shift speed and rpm significantly and see the results, aside from that I dont know what it changed. Also it doesnt shift into 3rd under part throttle as easy it revs up more, i have to be like 40% throttle or less for it to shift decent.
Any ideas?
The only part not installed in my car with the shiftkit was the manual down shift option.
Any ideas?
Tried lowering speed and rpm for 2-3 shift and it didnt have any affect. Even at part throttle 2-3 **** it revs higher to get into 3rd than before. If i am in 4th gear and floor it , it kicks down to 2nd gear even at 80. Goes to second gear at 6k rpm. Something in 3rd is messed up.
