Best way to cut a good 60' (A4)
I'm going to the track in a couple weeks. My best 60' is a 1.80 on M/T drag radials. I've tried different techniques. Hammer it off the line, raise the rpms to 1500. Can't seem to get out of the 1.8's. Also, I've read about people raising their rpms to 2800, how and the hell do you do that??? I can raise the rpm's to about 1800 before it starts moving forward. And thats standing on the brakes.
I'm looking for that 10 second slip. I know every car is different, but I should be cutting better than that.
Generally the bigger the stall the higher you can brake stall. My old TCI 3500 could go to 2400 rpms before it would start braking loose. My current circle-D 4400 stall can go to 3200ish. I know my best results when I had the 3500 stall was 19 psi in the tires, 5 second burnout and 2000 rpm brake stall mashing the gas on green. As long as I wasn't spinning it was good for 1.6x 60's.
I don't know why you can't go beyond 1800. That sounds kind of low to me. Might want to ask Dave @ Yank if that's normal for that particular converter.
I'm assuming you have stock 3.23 gears since your sig shows nothing on gears. The PY3400 is not an extremly hard hitting converter with a 2.3 STR and the 3.23 gears arn't helping much either. Still, I would think you should be able to hit low 1.7's.
I think you need a little more stall and a little more gear. Then the 60's should drop a lot. But I would seriously talk to Yank about your converter. While you got them on the phone you can ask them how much to convert your PY3400 to a SS4000
Good luck.
Good luck.
Darren, thats for the reply. I just sent Yank a PM regarding this. Yes, I do have a stock 10-bolt with 3.23's.
So, do you suggest raising the rpm's as high as I can to launch? Over just flooring it.
When I would flash the TCI converter off idle I would get 1.71-1.75 60's. When I stalled it up to 2000-2200 rpm's I would get 1.65-1.71 60's. That's what worked best for me.
Now I stall up to 2500 and go 3/4 throttle feathering into a full throttle. But that's because my stall is too big for 255/50R16 tires. I still get high 1.6x 60's though
Got ya. My best 60' was when I was at about 1500 rpm, so about 300 less. I'm just disappointed I can't cut a 1.7 with 550+ rwhp. I don't spin off the line either.
Flashing the converter means............flooring it off the line and not raising the rpms??? Sorry, illiterate.
I got 1.65-1.70 60's with 325 rwhp, 3500 stall and 3.23's. No reason you should not be there with a 3400 stall and 500+ rwhp.
Good luck.
Yeah I'd have to say that if you're leaving the line at immediate full throttle with no tires-spin on a 550 rwhp car on a solid axle...... then something isn't performing at it's best if you're not cutting below 1.80 60 foot with an aftermarket converter.
I'm running a Vigilante 3200 stall on my GTO, with factory 3.46 gears (a little higher than yours) but through independant rear suspension. Running on MT drag radials I'll pull low 1.5's all day long if the track is prepped well and I don't spin. I stall up to 1800-1900 RPM usually and nail it all the way down when I leave. Different car, but if I can hit low 1.5's with my setup you should be very well capable of low 1.7's at least with your setup.
With those power levels in your sig, you should be pulling the wheels off the ground just a bit! What are your times/traps. I,m cutting mid 1.50s all motor on a underpowered LT1 Pulling the front wheels just a bit with a 3600 Fuddle. What kind of suspension work have you done? Details, Details, Details!!
Mec
Mec
Mec
Only suspension mods are BMR (subframes, lca's, torque arm). Everything else is stock.
LS1Tech Premium Sponsor
http://lsx.streetfire.net/video/a7c7...2000a4809f.htm
