Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Aftermarket radiators
Old 12-14-2009, 02:51 PM
blk04V's Avatar
Default Aftermarket radiators
What are options for aftermarket radiators? I have a small leak but if I have to replace, I'd like to check out some of my other options first.
Old 12-14-2009, 05:07 PM
Sean01's Avatar
I got one from 1800radiators. $237 for a stock replacement
Old 12-14-2009, 05:32 PM
raven154's Avatar
Call Luke from Lindsey Cadillac. I think he can still get the Ron Davis aluminum radiator but they are pricey. I think in the 8 to 900 range.
Old 12-14-2009, 08:39 PM
VeryWhiteDevil's Avatar
ron davis radiators in AZ and never worry about it again. best of the best.
Old 12-14-2009, 09:33 PM
Darkman's Avatar
The Ron Davis stock replacement drops right in.
Attached Thumbnails Aftermarket radiators-pict0390_resize.jpg   Aftermarket radiators-pict0391_resize.jpg   Aftermarket radiators-pict0393_rotation_resize.jpg
Old 12-14-2009, 11:17 PM
blk04V's Avatar
wow! the Ron Davis piece is beautiful alright but a bit more than i'm lookin to spend. i may end up having to stick with the stocker... any difference with the radiator between '04/'05 and '06/'07?
Old 12-14-2009, 11:27 PM
itsslow98's Avatar
yea im with you 237>800-900..........especially since its not a race car
Old 12-14-2009, 11:29 PM
danv's Avatar
04 05 Cadillac CTS V Manual Cooling Radiator 19129908
ordered this one from this seller on ebay thepartsladi just received it a couple days ago. The best communication i have ever had from the bay, that part number is the latest replacement for the V oem, upgraded from the bad ones..
was $245 plus $12.50 shipped to my door.
hope that helps,
danv
Old 12-14-2009, 11:45 PM
blk04V's Avatar
^^^thanks. i'll check out ebay! ill also post up if i happen across an aftermarket one for reasonable $$.
Old 12-15-2009, 06:44 AM
Darkman's Avatar
The 2004-2005 and the 2006-2007 Vs use the same radiator. The OEM radiators were upgraded (in mid-2005) but both the original and the revised versions are failure prone.
Old 12-15-2009, 08:50 AM
i understand, but once you replace 3 radiators, you will understand, lol and it has nothing to do with being a race car, it's quality and durability and the plus is that it is an awesome piece
Old 12-15-2009, 09:50 AM
DoctorNick's Avatar
Is the Ron Davis any better at cooling then the OEM one? I am honestly looking to improve my cooling abilities however possible.
Old 12-15-2009, 10:24 AM
Darkman's Avatar
Yes it has a much larger cooling capacity. I suspect that Ron Davis Racing could give you a percentage. The pictures give some indication.
In my case, I frequently saw 210-215 degrees F in Houston, Texas stop and go traffic with A/C. With the Ron Davis installed I never see anything over 195 degrees (no matter what), which I believe is thermostat threshold.
Added note: I am also experiencing reduced oil temperatures.
Old 12-15-2009, 10:30 AM
scatillac's Avatar
Darkman,
Do you have any photos of your installation that you could post up?
I'm interested in the fan shroud fitment on the driver's side (especially in the bolt area) as I have minimal clearance there due to a larger MAF and intake tube. The area indicated on the edited copy of your photo shows where the issue is.
Old 12-15-2009, 11:28 AM
DoctorNick's Avatar
Sold!
You just made Ron Davis another grand
Old 12-15-2009, 12:14 PM
punishmentcycle's Avatar
Sold!
another thing u can do is grab a predator tuner or wherever tunes ur car...lower the fan on/off temps..i lowered mine by 10 degrees on fan #1 and #2 and never see anything over 190
Old 12-15-2009, 01:17 PM
Darkman's Avatar
Originally Posted by scatillac
Darkman,
Will take and post later today or tomorrow.
Old 12-15-2009, 03:28 PM
vmapper's Avatar
Luke does not bother with selling Ron Davis. He told me that right over the phone. And really not worth 800+.
Old 12-15-2009, 03:31 PM
vmapper's Avatar
you cant tell by the pictures?
Old 12-15-2009, 03:55 PM
SkullV's Avatar
He did, he was also the one who got Ron Davis to start making these.
Quick Reply: Aftermarket radiators
