Cadillac CTS-V Section 1/4 Mile Time List
#201
First time ever at a drag strip. Made 5 passes....I may be hooked on this sh*t so I best start looking for a back up diff.
A couple ?'s for the V1 guys: What tire pressure are you running in the rear tires? Are you launching with the TC on or off? All my runs were done with the TC off...
13.0948 @ 108.20 MPH 60' 2.0168 (KJR6306) V1 LS6 Maggie 112, 90mm TB, Dyno Tune.
Tires used on the pass: Continental Extreme Contact DW (Worn)
Performance Mods (if any): Maggie 112, 90mm TB
Category submitted for: Power adder
R/T.......... .1750
60'............. 2.0168
330'........... 5.7051
660'........... 8.6172
660’ mph... 83.62
1000'.......... 11.0407
1320'.......... 13.0948
1320’ mph… 108.20
Name of the track: Thompson Raceway Park, Thompson, OH
Date of pass: August 16, 2012
Weather conditions: (include Density Altitude, if known): 65 Degrees, DA 1951 ft.
[IMG][/IMG]
R/T.......... .1750
660’ mph... 83.62
1320’ mph… 108.20
[IMG][/IMG]
#202
I generally leave the tires at 30, and run with the TC on. Like you, I've had MUCH better luck with it on.
With some cooler weather, that Maggie will sing...not that 65 degrees is hot. But with heat soak and a better DA, you should hit deeper 12s easy...IMHO.
#203
Dude... thanks for the info.
All my runs were done with TC off....Minimal spinning through 3 gears. I had the tires down to 26 lbs by end of the night. Next time I'm going to make some runs with TC on. I know the Maggie likes the cold air. Will try to make it out again when it gets a little colder.
#205
New best for me last night at Gateway MSP
12.711 @ 112.07 MPH 60' 2.085 (randys14) V1 LS6 PRC 2.5 Heads, Texas Speed Tsunami Cam, Longtubes, LS7 Clutch, Tune
Tires used on the pass: Stock 245/45/18 Goodyear Runflats
Performance Mods (if any): V1 LS6, PRC 2.5 Heads, Texas Speed Tsunami Cam, Longtubes, LS7 Clutch, Tune
Category submitted for: N/A only
R/T............ .566
60'.............2.085
330'...........5.538
660'...........8.332
660’ mph.....88.05
1000'..........10.697
1320'..........12.711
1320’ mph..…112.07
Name of the track: Gateway Motorsports Park
Date of pass: 9/8/12
Weather conditions: (include Density Altitude, if known): DA 931 ft.
660’ mph.....88.05
1320’ mph..…112.07
#209
Updated time:
Tires used on the pass: Nitto NT-555
Performance Mods (if any): ls6 maggie 112, kooks/magnaflow, 90mm tb
Category submitted for: power adders
R/T..........0.516
60'.............2.075
330'...........5.446
660'...........8.178
660’ mph.....90.68
1000'..........10.510
1320'..........12.457
1320’ mph..…116.34
Name of the track: Maple Grove
Date of pass: 09/15/12
Weather conditions: (include Density Altitude, if known): 800 ft
R/T..........0.516
660’ mph.....90.68
1320’ mph..…116.34
#211
For Tom and some of the other guys who are able to get some low 60' times, what are you guys doing? I cant seem to get this heavy sled to cut a good 60'.
Maybe some psi tips, take off tips, etc. It could be helpful for all of us to share some more of these ideas now that this thread is going on its 2nd year.
#212
Sorry I don't have any big tips, I just launched from idle and mashed the pedal. Tire pressure was around 32 psi and the NT-555's hooked with no wheel spin and I was off. I don't bog at all, I guess that's about how I hit the throttle and engage the clutch but I'm not thinking too hard about it, I just go. Definitely have to slip the clutch a bit I guess to keep the rpms moving.
Launching harder results in too much wheel hop (I have no wheel hop fixes installed at the moment).
#213
2011 cts-v coupe
Tires used on the pass: M/T 305-30-19
Performance Mods (if any): 2.38 blower pulley, C.A.I, tune....
R/T..........0.096
60'.............1.78
330'...........4.911
660'...........7.456
660’ mph.....97.68
1000'..........9.618
1320'..........11.44
1320’ mph..…123.55
Name of the track: Gateway international raceway
Date of pass: 09/19/12
Weather conditions: (include Density Altitude, if known): low 60s
track was TERRIBLE. the car went mid 1.7s in bowling green every pass all weeekend at ls fest. as you can see i was fighting traction all night.
R/T..........0.096
660’ mph.....97.68
1320’ mph..…123.55
#218
Another PB for me. If I could have pulled a 2.0 60 foot like I usually do, I am gonna say this would of been a 12.4 or .5 run.
Have a cell phone video of this pass. Will post it later.
12.710 @ 113.44 MPH 60' 2.143 (randys14) V1 LS6 PRC 2.5 Heads, Texas Speed Tsunami Cam, Longtubes, LS7 Clutch, Tune
Performance Mods (if any): V1 LS6, PRC 2.5 Heads, Texas Speed Tsunami Cam, Longtubes, LS7 Clutch, , N2MB WOT Box, Tune
R/T............ .515
60'.............2.143
330'...........5.634
660'...........8.382
660’ mph.....90.46
1000'..........10.723
1320'..........12.710
1320’ mph..…113.44
Date of pass: 10/31/12
Weather conditions: (include Density Altitude, if known): DA -381 ft.
660’ mph.....90.46
1320’ mph..…113.44
#220
10.53 at 134.56mph
Did a track rental at Edgewater last Friday. 21 passes today in 5 hours! I put more passes on this car today then I have in it's lifetime.
Raised stall converter has me learning to launch fighting traction. Car has stock block still. Find more videos on YouTube channel weaponxmotorsports.com
1.72 60'
6.91 at 108.1MPH in the eigth
10.53 at 134.56MPH in the quarter
there is SO much left on the table with the way this is getting through the 330' at only 4.607
best run:
10.65 run:
http://www.youtube.com/watch?v=8U6HI6hP6pk
1.72 60'
best run:
10.65 run:
