Anyone got $13,000 laying around they want to give me?
If so, I was thinking I could pick up a new (well, used) engine for the V.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
2 31.2mm restrictors have ~32% the flow area of a single 78mm throttle body, and only ~24% the flow area of a 90mm throttle body, so that gives you some idea of the restriction this thing was breathing through.
I can only imagine how ridiculous the throttle response must be with the individual throttle bodies and all that power/torque!
Originally Posted by ebay
KATECH C5-R FIA GT1 CORVETTE RACE ENGINE USED
Own a piece of Katech history! This is a used FIA GT1-spec Corvette C5-R race engine. Over $85,000 new as shown
4000 race miles since last rebuild
9000 miles total on block/heads
425 cubic inches
4.120 bore
3.985 stroke
12.5:1 compression ratio
C5-R race block (not GMPP block - no liners - nikasil-coated bores) - hot honed with deck plates
CNC-ported C5-R aluminum race heads with bronze valve guides and copper berrylium Del West titanium intake and exhaust valves 2.180"/1.625"
Mahle 2618 forged aluminum pistons
Bryant forged steel crankshaft
Crower H-beam billet titanium connecting rods
Katech C5-R timing chain
LSM solid roller camshaft
Jesel 1.7:1 roller rockers
Jesel .937" solid roller lifters
Auto Verdi 5 stage dry sump pump (4 scavenge, 1 pressure)
Katech billet aluminum oil pan
Katech cross-ram carbon fiber individual runner intake manifold - 8 individual throttle bodies
Katech carbon fiber airbox tray
Katech aluminum a-plate
Katech C5-R carbon fiber valve covers
Katech modified LS1 aluminum water pump
Bosch ignition system
ATI damper
Recently validated on the engine dynamometer
552hp restricted through 2 31.2mm restrictors
596ft-lbs of torque
Can easily be converted to 700hp+ unrestricted
425 cubic inches
4.120 bore
3.985 stroke
ATI damper
596ft-lbs of torque
Intake is over $10k
Oil pump is $10k
I could go on and on.
You don't want to know what the price of the newer LS7.R is then.
$130k before it was DI
