Interior V pieces same as CTS?
I'm looking to replace the triangular-shaped rear side airbag cover that sits right behind the rear window on the driver's side (broken clip wont hold it on anymore). I'm going to scour Ebay, but wondered if this piece is V-only, or if the base CTS would be the same. What do ya think?
If you like to drive with the Windows down, you will keep changing them as well. It got so bad with mine, the dealership stopped putting new ones in and used some washers and wedges. Very known and documented problem the V.
