Won't idle - should I be surprised?
I've gotten my LS6 rebuilt with forged rods/pistons and added Trick Flow 220s and a 229/239 .627"/.621" 111.5+3 Comp Cam. I have a LS7 clutch, lightened RAM flywheel and a few other goodies like Kooks headers, a FAST 92 and a 90mm throttle body. I haven't gotten the car to the tuner yet and the car will run/drive but should I be surprised that it won't idle? Whenever it drops below 1000 RPM, it just konks out.
I have done the throttle body reset procedure and I'll also mention that I get some RPM surging when holding it above 1000 RPM.
yes, untuned and with stock injectors... like I say, I know I definitely need a tune but wondered if it was abnormal that it wouldn't idle. (it goes like a scalded cat but I have to heel to toe the throttle at stop lights...)
would you recommend different injectors?
New injectors would require new scaling for the injector cycle and window generally. Its weird it won't idle. I have seen many other guys that claim an even larger cam not have issues. Have you pulled any ECU codes that may she'd some light? Are all your sensors hooked back up? Like you MAF, crank an cam position sensors, for example. Just shotgunning some ideas around here.
Yeah you won't be able to run different injectors unless it is tuned. With that setup I would suspect you will be maxing out the stock injectors as is so...might be something to consider bringing with you to your tune/tuner. Ask them as they will know more. As for why it won't idle, I'm not sure. How long do you plan on driving it around before you get it tuned? I would check all sensors and grounds like ry said, as well as possible vacuum leaks.
Recheck everything. It would be a million things. But vac leaks and sensors are where I would start.
Another thing. When you out the FAST on, did it seal properly? In my experience... It is easier to get a vac leak in an intake manifold seal than it is to get VD in a shady club in Bangkok.
I did put new intake seals on the FAST but it's always possible it didn't seat properly.
With the problems I had with a short , it may be that I still have an issue with a ground somewhere.
Perhaps I'll take the intake off this weekend so I have more room to look around at the wiring and check the intake's seating
I wouldn't be surprised that it won't idle. My buddy did a cam in his car 224/228 and drove it for a week or 2. It barely idled and stalled all the time.
My C5 with heads and cam swap 234/242 ran like complete dick for the couple days before it was tuned. This was back in the day 2005-ish.
