c6/LS7 Luk Repset clutch & flywheel
I'm putting in a clutch as I'm pretty sure my slave cylinder is shot....and I'll be damned if the transmission is gonna get pulled and not get some kinda upgrades.
I started by pricing out the GM LS7 clutch which looked like it would be about $595 including the slave (plus shipping). Then I almost went for an Stage2 monster which with slave would have been about ($975) But then I check rock auto, grip force, and eBay, and after much scouring & homework, bought the Luk setup from amazon (quick shipping and easy returns)
LuK fw191 ($75 shipped amazon). The flywheel comes with nothing else (no bolts).
The flywheel is 27.8 lbs
LuK RepSet clutch 04216 or 04-216 ($286 shipped,amazon). The clutch kit contains most everything needed
So that right there is about $360 for a complete clutch setup shipped. I was very happy/relieved to to see the new slave included with the clutch kit. No flywheel or PP bolts...and I hope the pilot bearing is the same (yes, worked fine with my LS2)
I also bought.
- Pressure plate & sprung hub disc (assembly is 31.6 lbs)
- complete slave cylinder/TOB with hydraulic line (branded FTE)
(the hydraulic slave line is for the corvette. It can be used but is long, requiring it to be reshaped. You cannot swap the Stock line from your V1 slave, it will be too short. Tick makes a slave line for the Ls7 slave in the V1 trans....it requires clearance of the trans case) - pilot bearing,
- alignment tool,
- some lube/grease
I also bought.
- Tick remote bleeder ($50) a must have
- Tick line for c6 slave in a V1 ($50) not essential, YMMV
- Tick bronze isolator cup ($21)[edit: do not get this cup, it makes the shifting stiffy and notchy when the trans heats up. I will remove next time trans comes out]
- Brian's (07CTSV) bronze bushings for the shift coupler. ($50) recommended
- ARP flywheel and PP bolts (C6) optional
Excellent. Thanks brian! I was worried about the whole bastard transmission possibly having adiffent input shaft/pilot bearing.
I replace the flywheel and pressure plate bolts pretty much every time they come apart, unless its ARP fasteners. It is worth the $20 for all 12 bolts to replace the OE stuff with new OE fasteners... At least in my opinion.
I am this time, yes. The Allen bolts on the driveshaft to diff yoke are kinda jacked up, and the bolts on the coupler have been off 3 times now. I'm also going to replace the motor mount bolts and the bell housing bolts. Metal does fatigue and after 100k miles and being on and off a few times now, I'm just going to replace them.
There seems to be differing opinions on whether the flywheel bolts are TTY or not. Either way, if you've taken things apart a few times, its advisable to replace. Most replace ARP fasteners after being torqued 3 times. Essentially, I look at it like this, if its $1 per flywheel bolt and like $2 per pp bolt, why not. Arguably these are some of the most stressed bolts in the vehicle. They are subject to quite a bit of heat from friction and the motor, as well as shear force.
There are torque + degree bolts that aren't tty as well... The main cap fasteners are not tty and they are torque + degree... I'd still replace those if I have to remove them again for a crankshaft change. Metal isn't super elastic. When you stretch the bolts during torquing, they don't come back 100%. So after a few times, you'll want to replace things. I went with ARP head studs on my build, but reusing OEM for the main caps. I know that I'm likely going to be doing more head work, and or new lifters at some point because of my aggressive cam. I want to be able to reuse my head bolts/studs a few times.
Also the flywheel and pp bolts are torqued in stages. 1/3, 2/3, and full.
OK I take back. I prematurely freaked out while hand threading a bolt into the crank and it was sticking way out when it felt like it bottomed out. But the V1 flywheel is about 1/4" thicker than the C6, and the flywheel bolt lengths differ by about the same amount. So the V1 bolts will thread quite a bit deeper into the crank, than the C6 bolts would.
