Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Line lock
Old 07-22-2015, 02:23 PM
BlackSS/SC's Avatar
Default Line lock
Who's done a line lock on a V1? Mines an 04. I've read about lots of issues. I plan on putting it between the master and abs unit. Only info I could find is the abs will bypass the fluid allowing the brakes to release. So couldn't I just pull the fuse before I use it at the track?
Old 07-22-2015, 03:15 PM
barrok69's Avatar
Why don't you install it after the ABS module? I'd imagine either way you are going to get faults in the system if you don't pull the pump fuse.
Old 07-22-2015, 03:18 PM
BlackSS/SC's Avatar
Because one line runs from the master cylinder into the abs unit, then two lines run out, one to each wheel. I'd rather not have to use two solenoids as I have one here already.
Old 07-24-2015, 03:00 PM
BlackSS/SC's Avatar
Well can't do what I wanted. Was thinking our cars master cylinder used one half for front and one half for rear brakes but it used a cross diagonal setup. Dammit
Old 07-27-2015, 06:08 PM
incubusjunkie614's Avatar
I've looked into this, you will have to wire two separate solenoids, one switch, one solenoid on left front and one on right front. You would step on the brakes, hit the switch, the release brakes, freeing rear wheels and keeping pressure on the front brakes. hypothetically you could hook them up in the rear as well, which essentially would prevent the brake fluid pressure from reaching the rear wheels. I'm sure you'd set abs/ traction lights however you do it. I decided against it because of the rear end and I tend to run stickier (expensive) tires.
Old 08-04-2015, 09:12 PM
BlackSS/SC's Avatar
Put them in this weekend. There was a perfect spot on both sides. Just cut and flared the existing lines. No abs light or anything when using it. Pic is the passenger side.
Old 08-05-2015, 07:39 PM
Looks good. That's where I would have put them. Now I'm curious how long your diff holds up to all these upcoming smoke shows
Old 08-12-2015, 06:37 PM
BlackSS/SC's Avatar
8.8 already
Old 08-12-2015, 07:29 PM
IH8FORD's Avatar
Any problems getting the brakes bleed back out?
Old 08-12-2015, 07:50 PM
BlackSS/SC's Avatar
I work at a garage so we have a pressure bleeder and scan tools for abs bleeding. So it was no problem.
But I did try manual bleeding first and couldn't get any flow happening. I removed one line at the abs pump to cut and flare it easier so I did loose a lot of fluid.
Old 08-12-2015, 09:00 PM
NIKDSC5's Avatar
Think line lock will work holding just one tire?
Old 08-12-2015, 09:31 PM
isis's Avatar
Pretty clear he did both sides but only posted a pic of one.
Old 08-12-2015, 09:47 PM
NIKDSC5's Avatar
Yup. Got that. I'm wondering if you need both wheels to hold, or if one would suffice. Savvy?
Old 08-12-2015, 09:49 PM
isis's Avatar
Oh. That just sounds dangerous. Thought you were trolling. Carry on.
Old 08-15-2015, 12:59 AM
BlackSS/SC's Avatar
Got to use it at the track tonight. Worked great. Still gotta work on my 60 foot times. Best was 1.9 on et street ii 265/40r18. Ran 12.7 111mph
Old 08-23-2015, 01:12 PM
somethingclever's Avatar
What was the DA?
Old 08-31-2015, 10:55 AM
IH8FORD's Avatar
Which line locks did you go with?
Old 09-02-2015, 08:53 AM
CTS-V Shifter Sales
07CTS-V's Avatar
He used two of these.
http://m.summitracing.com/parts/tci-861700
Quick Reply: Line lock
