I need new pads and rotors 07' V.
I just saw this post linked in another thread, so I decided to update my comments. The HPS5.0 pads work really well in terms of pedal feel, travel and linearity. High and tight. They dust a rust-ish color something fierce and make it difficult to keep my wheels clean. The rate of dust production is greater than the HPS I've run in the past on other cars, but that was the only real downside over the old HPS compound. Because my V is mostly a commuter, when I get off my lazy ***, I will pull these pads in favor of something a little less aggressive in effort to have less dust.
I do like 'em, but I wouldn't say they're a low dust option. I suppose you can try them out and see if they're un-dusty enough for <$40, so it's not much of a loss if you don't like them.
The same could be said for a variety of other options, too - there are a ton of semi-metallic pads in the D1001 pad shape. You could try 4 or 5 different sets for the price of a single set of HPS or HPS 5.0s.
If you're not in a hurry, Amazon will have sales with free shipping sometimes, I just picked up 4 new oem acdelco rotors for ~275 shipped (which I found to be a great price on the stock rotors).
That said I'm up in the air about the pads. I'd like to go with something as good as stock, but am unsure about the cheap semi-metallic pads.
I got those pads also but they dust much less than the ones that came on my car. I have not had problems with squeaking and I am pretty happy with there performance. But the problem I have is after I wash my car if I don't go for a drive and heat them up they leave pad material behind and I get pulsing. I had to sand off the pad marks before I figured this out. I have the centric premium rotors. Has this ever happened to you or anyone else that has run them?
I've got the Powerstop Evolution brake pads that came with my Brakemotive package. After 50k+ miles, I can say that the pads are very durable, low dust, make absolutely no noise, work very well when they're properly warmed up and are just fine for daily duties. I wouldn't be surprised if these pads lasted another 20k. Plenty of material left on them.
#33
Not to thread jack but would the autozone duralast rotors and the duralast gold pads work good on a daily? They were givin to me with the purchase of the car, I want to change them the ones that are on there now squeal a lot and leave a lot of brake dust but the pad still looks good so I'm assuming the rotors are glazed
#34
I also broke 2 sets of rear rotor e-brake drums. I have my e-brake adjusted tight enough to actually work and the rotors are so thin in this area, they couldn't take the stress and literally started breaking in half.
I had their Bendix pads on another V I had and while they did a little better, they still would shed material and "warp up" if you didn't really baby them.
I inherited a set of unknown slotted rotors and pads from the before mentioned V I just sold. Based on how they look, I'll assume they're the Brake-o-motive parts and so far, they're working well on v1 number 2, my daily driver.
#35
