Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
switchblade key fob "mod"
Old 10-03-2016, 04:42 PM
vroom_vroom's Avatar
Default switchblade key fob "mod"
My factory Keys and fob drive me nuts being a tall guy. The fob is always on my knee and it drives me mad. Losing the switch blade key was the only think I regretted about selling my Camaro for the v. Found a seller on eBay (posted link below) who makes them with the pk3+ chip and the correct electronics for the fob transmitter. Was kinda skeptical about the Chinese key but was impressed when it showed up! It's a vw/Audi case so it's made well and pretty solid. the seller has two different styles but one is a 3 button and this one was a 4 button fob. i wanted to retain all the buttons.
Had the key cut and programmed it today and immediately I'm in love. The clearance is great, no more rubbing on my knee and it will not poke holes in my pockets any more..........
Gonna order a tech II this week and get the fob programmed, hopefully it will have a decent range to it and actually work. The oem fob you have to drop half the time to get it to work even after I took it apart and cleaned it. So as long as the fob works this will be a solid option and I will buy another one! Stay posted for fob details!
ebay seller: artiway
http://www.ebay.com/itm/361536433576...%3AMEBIDX%3AIT
http://i795.photobucket.com/albums/y...psxalh6avy.jpg
Old 10-03-2016, 05:15 PM
jcollege's Avatar
What was is entailed to get the new fob programmed?
Old 10-03-2016, 05:24 PM
Find someone with a tech2 or go to the dealer.the key you can do yourself.
Had it cut, put my original one in, turn to run wait for the lock symbol to go out and immediately do the same with the new key and presto.
Old 10-03-2016, 07:05 PM
Mercier's Avatar
If the fob works, I am getting this. Nice find!
Old 10-03-2016, 08:16 PM
FuzzyLog1c's Avatar
LS1Tech 10 Year
While you were at it, did you notice these other designs?
http://www.ebay.com/itm/USA-FLIP-KEY...-/361536435292
http://www.ebay.com/itm/R8-FLIP-KEY-...-/131784289740
Old 10-03-2016, 08:19 PM
I did, they where the other ones I mentioned, there is no panic button. If you don't care about having it then they should work. I wanted full functionality. The one I got had the panic button built into the side
Old 10-03-2016, 10:09 PM
Mercier's Avatar
Did it also come with a cute little pink can of pepper spray?
Old 10-03-2016, 11:13 PM
lol several rounds of hydrashok for that
The panic button is for giving the wife a heart attack!
Old 10-04-2016, 08:45 AM
05CTSV's Avatar
LS1Tech 10 Year
Can you still use it to reprogram your tire pressure sensors? Have you tried that to see if it recognized the press of both lock and unlock? If that still works, seems like a nice upgrade for sure.
Old 10-04-2016, 12:23 PM
Not sure yet, as soon as my tech2 shows up I will find out. But it operates on the same fccid as the old remote so yes it should retain all functionality. We will find out soon.
Old 10-04-2016, 07:16 PM
CTSvOH's Avatar
I had one of these keys for another car. I like the switchblade key because it doesn't take up much room in your pocket. Unfortunately the switchblade action broke fairly quick and it ended up being more like a knife you have to flick open with your wrist. Besides that, I was still happy with it. Does it have a Cadillac emblem on the back?
Old 10-04-2016, 09:10 PM
Yup, ordered a v badge to but on it because I can't leave well enough alone. Hopefully the tech2 will be here first of the week. I figured if the case was an audio kinda deal I could always raid parts from one as they are readily available and dirt cheap.
Old 10-05-2016, 07:15 AM
ramairetransam's Avatar
LS1Tech 10 Year
i want a flip key for my 99 trans am . I have vats deleted so it should be simple .
Old 10-05-2016, 08:59 AM
Anthony Toal's Avatar
Let us know how it works out, if the range is significantly better, I will get one for sure
Old 10-05-2016, 02:37 PM
you will need to find a unit with the correct receiver frequency and program it. the key is not your issue, you can take the key you already have cut it and put it in the fob.
Old 10-12-2016, 03:22 PM
*update*
so my tech 2 clone came in today, im already in love with this thing(thanks byron)
but back to the fob. i reprogrammed the old fob into slot 1 and the new one into slot two so i wouldn't lose all my settings as the only fob i had was the original #2
took the programing just fine and held my slot settings. works like a charm and has a vastly improved range over the stock turd. however even the oems range seemed to be slightly better after reprogramming. not great but i dont have to drop it to get it to work for now..............
if you want to do this and your in las vegas let me know if you need access to a tech2 instead of throwing $$$ at the dealer.
i will get a better video of the range after work tonight when its dark.
Old 10-12-2016, 03:36 PM
Mercier's Avatar
If only I could cross things off the "gotta buy" list faster than I add them.. Alradco rad or Tech II clone.. Hmm. I need the rad but "winter" is coming up. I say "winter" because here it just means it won't hit 90s every day of the week.
Old 10-12-2016, 03:50 PM
i feel ya! gotta order a new clutch this month, then headlights, and i really want to rebuild the entire cooling system as a preemptive strike. then there is the go fast stuff your not supposed to do to a daily..................
Old 10-13-2016, 01:32 AM
AiDRocks's Avatar
Can they be programmed with after market alarm systems? If that's possible, I'm sold!
Old 10-13-2016, 03:00 AM
Is it an aftermarket controller and fob or is it still on the stock key fob? If it is then yes I would imagine so as the alarm would be relying on the stock radio transmitter
Quick Reply: switchblade key fob "mod"
