Ctsv lsa blower stock hood
#32
I moved the radiator forward a inch at the top and 2 inches at the bottom . Stock fans . Abs modulator is in oem location . Used adaptor plates to mount blower to heads. Around a inch or so of clearance on the balancer. There's enough room to change the belts if needed to
#34
Yep. You can do it. But like with the LS6, the stock connecting rods aren't going to take more than 7-8 psi boost before epic failure.
These are designed to clear the V2 blower alignment pin:
http://www.dirtydingo.com/shop/produ...oducts_id=1687
#37
#39
Hmmm, where did that estimate come from? I have seen several folks running 10 psi but I have no idea how long the setup lasts. I have been on 7.5 psi for several years and no problems with the bottom end so far. I do believe that the tune has a LOT to do with how much boost these will take. The E67 controller and OS on the 06-07 is not the greatest (the E67 is good but the OS leaves a lot to be desired when dealing with boost). I bring this up because if you are experiencing knock then obviously the bottom isn't going to last as long.
