Bone stock 1/4mi record 04-07
Dragtimes.com keeps a record of that. As of now 11.8 is the fastest. Although there are several beasts being built now that are 800+rwhp with Madman rears. They will break that.
http://www.dragtimes.com/results.php...e=10&carmake=7
No way that's bone stock. The calculator I found online says 12.70's@110 for a 4200 lb car (includes driver) with 405 HP. I'd guess that's with a 1.6 60'. I guess another good question is what's the fastest 60' in a first generation V? From what I've seen 1.60's are nearly impossible with this car
If the previous owner did not show you the time slip . . . well then, I suspect that statement by the seller could be the 4th or 5th biggest lie, next to the 'infamous 3'.
when you say stock, headers?? it ranges all over the board as the members now actually drive this car instead of ***** footing around the rear end.
I go to the strip as often as I can, of course I do have axles, but if you let off when hopping, it will stay together. So what you run an 18 that time, saves you alot of money. I make at least 8 passes each time I go and you know within the first 60' if you should give it up in this car. you will only frustrate yourself and be amazed you run 107mph, lol. I am there myself some nights.
sorry, just cant believe he went one time on a stock v and ran a 12.8. One time, BS
