Methanol Injection for Maggied V1s
I have seen a few post they are running kits, does anyone have a before and after dyno? IAT comparison? How many mpg are you getting with the methanol? Any issues after install? Where are you injecting?
I have never played with meth injection but have read many times of the claimed results. I like the possibility of running a race gas tune while running pump gas and the additional safety net of the reduction in possible detonation. Just trying to get some info together and have been unable too through searches here and on CF.
you have to be careful with meth its addictive , but in all seriousness meth is a beautiful thing, just lowering you IAT's alone its worth it and then not to mention you can run more boost and timing its like running race gas.
No experience on a V but my brother runs it on his grand national. On pump gas before meth he was running a max of 17-18psi before hed get detonation. On meth hes running 28psi. So pump gas hes making a ton more power with zero detonation. I would reccomend alkycontrol's kit they are top notch.
BTW meth has nothing to do with mpg its not like E85.
I use an Alkycontrol.Com kit on my turbo Buick and I run 22 PSI of boost on the street. They just designed a kit of '09 & up CTS-V's, but I don't know if that kit can be adapted to the earlier V-1's. I have his kit for my V2, just not installed yet. One of the guys over on the other forum got about 20 RWHP & RWTQ out of his V2 kit, but I think that he is running a modded Snow methanol kit. Ask any of the turbo Buick guys, they all run meth.
I wouldn't mind a meth kit, but I already have an *** load of timing from the E85, would it be safe to turn it up more? or will I even gain anything from that? Perhaps just the cooling ability itself would be nice.
I dynoed before and after. Before was 45deg in the winter after was 95deg in the summer. Picked up 2hp and 25tq. Tuner retuned fuel map and added timing. Alkycontrol kit for a C5 vette. Setting is at 4.5, nozzle is at the TB. I will dyno it this winter.
Remo
Remo
http://www.scandc.com/images/New%20p...tall%20001.jpg
I love Alkycontrol.Com & I love my methanol set-up. I used to run 100 octane VP unleaded but the cost keep increasing. I believe that 100 octane unleaded is now about $ 8.00 a gal. (in Kali). The way that most peeps look at it is with meth you will get a few more RWHP & RWTQ than race gas with the same settings or you can run a few more PSI with meth than you can with race fuel due to the cooling effect. That's everything else being equal.
I have always heard that spraying meth pre blower will wear the teflon off your rotors and cause the blower to become very inefficient, can anyone verify if this is true or internet rumor.
thanks for the input so far, what i meant by mpg above was how many miles per gallon of meth, not fuel efficiency just wondering if anyone has this in a DD and would need to pay attention to that. I wrote alkycontrol to see if they have worked with a v1 before, waiting on a response. 25 ft/lbs is a nice pick-up. I have read for best results to install post blower as well. Gary where does the nozzle install with your v2 kit?
A few guys tried plumbing meth in the intake manifold after the blower and IC but I dont think it worked very well on the positive displacement units atleast not enough to be worth the effort anyway.
Meth and a cam really helped the top end of my maggied V. After it was totaled I got another maggied V w/out meth. Haven't transferred the kit over but I can remember how the top end felt better while spraying meth.
Just a little added protection against detonation. I called Maggie and snow performance about the rotor issue and they said it could be a problem with poor quality materials etc..... On turbos and centis, they inject it post-compressor because the blades will get damaged at the speeds they travel. Not so with PD blowers.
I'm new to this game but is the meth injection used all the time, only on a WOT switch, or when you want like nitrous? And what product do you actually buy and how often do you refill? Every tank of gas, more, less?
tex what kind of #s did you see with your previous V? good input on the rotor issue, so i assume yours was sprayed pre-blower then?
tshort - i don't have much info, but from some friends who ran it in f-bodies they would get approx 2500 miles out of 3 gallons, but it all depends on how you drive. i'm not sure if all kits are progressively controlled, but the kit i was looking at activates depending on throttle position. in other words the injected amount depended on throttle amount, so not necessarily a microswitch for WOT like some nitrous kits but more of a progressive meth unit with a controller. i'm sure the wizards have better input for you
My alkycontrol kit is not installed yet (on my '09 CTS-V). Alkycontrol is a supply on demand system. It comes on at about 5 PSI, & increases in strength or amount sprayed as the boost increases. A bud of mine and I split a 5 gal can about every 9 months or so, sometimes a year. I put about 3500 miles on my car in a years time. My bud might use a little more than I do as he runs a 10 sec GN on the street and has it dialed in at about flat 11's for the street. He dynos 510 RWHP & 520 RWTQ. He probably gets in his a little more than I do. There is a wealth of information on turbobuick.Com, "Nitrous, Propane, and alky section". There is also a wealth of info on alkycontrol.com. Read, learn, & decide for yourself if it is for you. I would never leave home without it.
To Zinner, meth is like 30 for 5 gallons, lasts months, and gets you a decent amount of power(not nearly as much as a turbo car or other platforms) but come on track only? thats BS. Wish you could have ridden in my brothers GN pre meth and post meth. Itd sure make a believer out of you. And also meth is perfect for cars that see the street a lot, it allows them to run race settings on pump gas. If anything id say meth is for the street, race gas for the track.
