Quick question about jack stands
I'm looking to pick some up so I can do maintenance on the V myself, but I've never had a set before. I have a set of ramps that I have used since my first car, but all I've been doing was oil changes and fluid changes on my wife's Jeep.
I plan on eventually getting headers, doing brakes, painting wheels, etc that would cause me to need to get a set of stands to lift the whole car up.
How much clearance is needed under the car to be able to get in and out? I'm considering a set of stands with a floor jack that have a max lift height of 15" on the jack. Is that going to be enough to crawl around under there and work relatively comfortably?
Try Torin 3 or 6 ton jack stands--I just picked up four 6 ton jacks. They were $40 per set + shipping from Amazon (so about $100 for everything). The reason why I went with the big ones is because they can go up to 24"--if you're planning on removing your transmission, that extra height is key.
Of course, you'll need a hydraulic jack that can get you up that high in the first place.
