Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Quick question about jack stands
Old 04-08-2011, 01:22 PM
Schoeny's Avatar
Default Quick question about jack stands
I'm looking to pick some up so I can do maintenance on the V myself, but I've never had a set before. I have a set of ramps that I have used since my first car, but all I've been doing was oil changes and fluid changes on my wife's Jeep.
I plan on eventually getting headers, doing brakes, painting wheels, etc that would cause me to need to get a set of stands to lift the whole car up.
How much clearance is needed under the car to be able to get in and out? I'm considering a set of stands with a floor jack that have a max lift height of 15" on the jack. Is that going to be enough to crawl around under there and work relatively comfortably?
Old 04-08-2011, 02:34 PM
punishmentcycle's Avatar
get 2 1/2 ton or better...make sure you put them at the jack points on the FRAME..not the pinch welds.. get it up as high as u can but be careful when jacking up on the other side thats still on the ground.
Old 04-08-2011, 03:57 PM
wcryan's Avatar
yeah that
Old 04-08-2011, 07:47 PM
FuzzyLog1c's Avatar
Try Torin 3 or 6 ton jack stands--I just picked up four 6 ton jacks. They were $40 per set + shipping from Amazon (so about $100 for everything). The reason why I went with the big ones is because they can go up to 24"--if you're planning on removing your transmission, that extra height is key.
Of course, you'll need a hydraulic jack that can get you up that high in the first place.
Old 04-08-2011, 08:26 PM
Stone17's Avatar
I have 4 of Craftsman 2-1/4 ton Jack Stands.
http://www.sears.com/shc/s/p_10153_1...2&blockType=G2
Old 04-09-2011, 04:42 PM
wcryan's Avatar
I think anything on sale would be the best bet. They are all pretty up there in quality; just because they arent really difficult to make
Quick Reply: Quick question about jack stands
