Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Katech Shifter Shift knobs Solution Found
Old 08-03-2012, 03:11 PM
Dmax/04V's Avatar
Default Katech Shifter Shift ***** Solution Found
My TWM weighted **** came in today (took a month). Those of us who have a katech short throw shifter know it is damn near impossible to find a good **** that is threaded and fits. If you order a TWM **** in a 9/16-18 thread pattern the insert can be bored out and retapped to accept the katech shifter with minimal effort. Took me all of 15 minutes:
1. I used a vice to hold the insert in place
2. Drilled the insert out with a 1/2 inch bit
3. Insert lock nut and insert into ****
4. Put tap in vice, and twist **** until insert is fully threaded.
The TWM **** has a very solid and connected fit, well worth the wait and 15 minutes of labor.
Old 08-03-2012, 03:25 PM
NeverSatisfied02's Avatar
Nice! Is 9/16" the size that accomidates the stock shifter?
Old 08-03-2012, 03:28 PM
Dmax/04V's Avatar
9/16-18, it is the easiest to modify because it is only off by 1/16 of an inch. Still has to be drilled out and tapped, but that is the size I ordered.
edit: I have no clue which one fits stock shifters, this was for katech. I'm not sure what the stock size is.
Old 08-03-2012, 03:51 PM
furbe's Avatar
This is why the Katech shifter comes with a 5/8-18 tap included so you can tap the factory shift **** or any other **** you want. Why not order your **** in the correct 5/8-18 thread?
Old 08-03-2012, 04:05 PM
Dmax/04V's Avatar
Well furbe...go ahead and find me someone who makes a shift **** in that size, also try to explain to the canadians who run TWM that it would be worth making an adapter in that size. in fact.
Old 08-03-2012, 04:24 PM
eBay has ***** in the size needed for the katech. They are just standard round ball ***** like the hurst **** but look nice for the money.
Reason I'm asking if the stock size shifter is 9/16 because I'm looking at a used CTS-V TWM **** and I have a katech shifter.
Old 08-03-2012, 04:41 PM
odthetruth's Avatar
^ wt*****?
Old 08-03-2012, 05:00 PM
Yeah... not sure what the *** is about...
Old 08-03-2012, 07:40 PM
VeryWhiteDevil's Avatar
for some reason the pictures of your shifter**** are not showing up at all
Old 08-03-2012, 07:55 PM
Dmax/04V's Avatar
I'm more confused by the ********'s all over the place?
Old 08-03-2012, 08:08 PM
Did someone post pics of a shifter ****?
Old 08-03-2012, 11:42 PM
furbe's Avatar
The stock shifter is not threaded, the shiftnob snaps on. This is why Katech includeds a 5/8-18 tap so you can tap threads into the stock shiftnob. (or any ball **** or handle of your choosing.
I called TWM, dude said although they do not show 5/8-18 thread as an option on their website, it would be no problem to thread your custom order ball with this thread size. Just call them.
Old 08-03-2012, 11:55 PM
I know stock is just push on but it's the diameter of the shifter I'm still interested in so I will know if this used **** I'm considering will work for me or not? It's ordered to the fit stock V shifter.
Old 08-04-2012, 12:27 AM
Dmax/04V's Avatar
The whole point of this thread was to show that the fitting's TWM uses can be drilled and threaded. TWM does not make a shift **** that is threaded to a certain size, just an insert. This insert has enough meat on it to be threaded to a katech short throw.
Old 08-04-2012, 12:56 AM
I have a Katech too. still wanted to see a picture. I threaded a MOMO ball, but would like to have another option. Fcker gets hot in the summer here in AZ.
Old 08-04-2012, 02:14 AM
clonedws6's Avatar
Wtf ***** I don't get it *****
Old 08-04-2012, 08:50 AM
I know the point of the thread but without a drill press, I'd prefer to not have to take much off the sleeve to make it easier. That's all. I know any size can be drilled to fit.
Old 08-04-2012, 11:08 AM
9t8z28's Avatar
I don't see why everyone thinks Katech uses a uncommon thread. Its the same thread used in F-bodys. There are lots of shifter ***** available.
Old 08-04-2012, 11:32 AM
Are you sure about that? I've searched and haven't found **** for 5/8"-18. Only a couple options and I found some basic machined billiard ball style ***** in steel and stainless on eBay threaded to fit already.
Old 08-04-2012, 12:51 PM
aurora40's Avatar
LOL at the **** for "****"...
Quick Reply: Katech Shifter Shift knobs Solution Found
