Hurst shifter for the 2004-2007 CTS-V.
#161
Hi, I just bought an 05 V today and i'm interested in this as well. When you mention the set of polyurethane outer linkage bar bushings from Crestive Steel do you mean the "poly - shifter support rod bushings" option from https://creative-steel.com/store/ind...t_detail&p=181 for $25 or do you mean the kit that includes both for $75?
I'm just trying to get everything understood before I place my order with you.
Also, do you include instructions with your kit?
Thanks!
Thanks!
I send detailed instructions with each kit.
#162
#167
NOTICE:
All Hurst shifters are now being modified and shipped with two Delrin bushings in the base. I originally only replaced one of the stock nylon Hurst bushings with my own Delrin one but I have found some of the nylon ones are wearing out and/or flat out breaking. I have also just recently found a couple that were bad straight from the factory. This does not mean that every one with a white Hurst bushing will go bad.
If your shifter does not have TWO black bushings in the base I will send you a new bushing to replace the white one with. Free of charge, all you have to do is contact me and let me know you'd like one.
#168
My shifter originally had one of the white nylon hurst bushings. It ended up failing so I contacted Brian about it. He offered to make me a set of the delrin bushings free of charge. Great service!
I've had the newer delrin ones in for about 3 months now and they made a big difference. Definitely worth the upgrade.
#170
Brian being awesome as always provided an adapter for my shift ****. Here you can see the size difference between the stock Hurst & the one I bought from ebay. You can clearly see the size difference:
FYI: the stock Hurst **** is for sale if anyone happens to want the black one. I'm already thinking about my next ****!
The only issue with the adapter was that it fit kinda loose & I was considering some loctite to nail it down. I ended up sticking a rubber vacuum cap inside it to give it something to bottom out on & then allow the jam nut to hit the **** vs the adapter. Rock solid, no loctite needed.
I drove for an 40 mins in traffic to get home with the lil hurst **** & it was tiny in my hands & I don't really have that huge of hand. This aftermarket **** feels sooo much better.
Also, this Hurst shifter is the bees knees. Daggum, it's tight as hell & add the Phillstine Clutch Master Cylinder, it's learning how to drive the V all over again. It's shockingly short, I wasn't expecting it to be that short. I made my aftermarket **** stand a lil higher so I could get some of it back. I also have to re-learn just "feeling" what gear I'm in based on my hand resting on the shifter & being able to just make the right up/down shift as needed w/o thinking.
All in all, I'm happy!
The other day, the 'waiter' at Sonic saw my black/white **** & was like "that's a cool shifter".
#171
.....The only issue with the adapter was that it fit kinda loose & I was considering some loctite to nail it down. I ended up sticking a rubber vacuum cap inside it to give it something to bottom out on & then allow the jam nut to hit the **** vs the adapter. Rock solid, no loctite needed.....
#172
Thinking about it, I could've stuck the same size internal thread bolt from the other end (provided the head fits). I dunno, nothing really stops the adapter from spinning inside except maybe loctite or something like the cap.
Something to think about to figure out for a more practical solution? Maybe affix a jam nut to the adapter (weld/jb weld/loctite) & leave it long enough so the user can lop off the length as needed.
#173
I'm a little interested in this kit of yours. I like the feel of my stock shifter - it's very smooth and easy to slip in gear. My only complaint is the motion to get into gears is just a tad too long. So will this shifter maintain the smoothness and ease of getting into gear, albeit reducing the throw significantly?
Also, what if I don't get the $25 poly outer support rod bushings from Creative Steel? What are the affects of not having this?
I like the factory **** and current height where the shift **** sits. Is there a way you can maintain the shifter height with this kit? I want to be able to use my stock shift boot without having to modify anything to make it look good.
#174
I can modify the extra stalk in the kit so you can use the stock **** and boot. I can also retain the stock **** height if you'd like. As a standard, I make the modified ones so the **** height is about 1/2" lower than stock. If you do want one made, please request that I make it the same height as stock.
#175
This is pretty low. I tried making it so the adapter would give me some height back.
I can get a better side view, but I don't have a stock height "before" pic.
#177
Hurst sells a chrome stalk that is 1.125" taller than the one that comes in the kit. It is also straight instead of slightly curved.
https://hurstshiftersonline.com/prod...&idcategory=51
I can make you an adapter to raise your current chrome stalk if you don't want to spend $60 for the longer Hurst one. Message me and let me know how much taller you want it. It will be crude, but it'll work and be entirely covered by the boot anyhow.
#179
The modification is for the 'extra' Camaro upper stalk that I modify to be able to use the stock CTS-V ****.
#180
Just have to say. I just installed a Hurst shifter from Brian. I love it. Thanks for a great quality product and thanks to my son Zac at UMIPerformance for getting it for me.
