Whipple off, rethinking my next option
#101
Probably going with a safe tune to start, I have to break in my clutch, not sure a bunch if hard dyno pulls would be good for it. I also have a smaller pulley, for when I do more to the fuel system. Right now I have a aeromotive 340, hot wired to the alternator, and a kennebell bap on a 5 psi hob switch. It should be enough for now, but I'm sure when I start to push it, I will need more. I'll probably start the fuel system this fall. Then get some final tuning done.
#102
#103
Regarding the fuel system, you can get some ideas from my posted sticky. It has every part of the fuel system exposed for the most part. I have some calculations that I can send to you along with a comprehensive parts lists that you can sort through. In theory, it's good for 1khp or 850whp but most systems I've seen in the speedshops have 3 fuel pumps for 1kwhp - I use two DW300's with 13.5volts and it flows a ton of fuel with a full return and aftermarket regulator.
#104
Taking notes on this build...
tommycompton@msn.com
#106
I got the BAP back in yesterday and logged a little bit. It's set on max which I think is 17.5V on a 3psi switch. I installed a pressure sensor at the rail so that I can log it and its dropping to 50psi at the rail high load high rpm. Before it was down to 30 so a big improvement there.
Philistine's dual pump setup is great. I would love to have a boost referenced pressure regulator but I'm not excited about all of that plumbing. A 24V race amplifier might get me the rest of the way.
#107
Delay in posting, but she's running. Just gotta wait another week or so to get it in for a tune.
Currently wrestling with my innovate aux box to get my gauges to work for my dashdaq.
Trimmed up the Edelbrock covers, they fit pretty good, got them repowder coated.
Had some vette cover stickers kicking around, might ditch the vette logo but keep the LS2 decal.
^^ a little idle video.
#114
I emailed that guy selling his 05 redline, and I enquired about his stock wheels, but that trail went cold when I offered fair market cash for the set. I should ping him again.
Who's tuning for you?
#115
Still have mine! Been out to Gimli a few times this summer with it, having a ball with it, lots of go-fast fun out there. I've developed a front end clunk, we get together sometime I bet you know what I need to replace on it if you hear it.
This time I'm going to motion performance, apparently they remote tune from a well know tuner in the US.
I've been to walls and dragmart before. Wasn't impressed with either. Walls uses efi live, and I already have a tune using hp tuners, plus I heard they are no longer writing tunes for non diesel . So who knows.
Drag mart should be called drags their *** lol, takes them months to do anything.
A buddy knows the guys at motion so I guess I'll give them a try.
I'd almost fly someone up here to do it lol.
#116
Great job. Thanks for doing all the home work on this and kudos to the vender for selling the parts from a kit his customers actually want.
Just so I am clear, the LS2 title of this blower only refers to the routing of the snout and pulleys correct? It does not actually have a lower manifold that will fit LS2/243/799/cathedral port (what ever you want to call them) heads. In your first pic you have your ports covered but you have LS3/rectangular port gaskets sitting on your valley cover. I can only assume with your compression ratio and gaskets you have LS3 heads. Sorry for the dumb question but I can't seem to find the answer I am looking for.
#117
The blower part number will fit on cathedral ports,the snout direction is correct and pulley offset is the same as the Ctsv.
So it will work on the ls6 and ls2 Ctsv.
Hope that helps.
