Map lights dimmer switch
Just curious on the dimmer switch is there a light that is suppose to be there? I have the 2 square map lights and then light around the circle for the sun roof but is there suppose to be a light for the dimmer (white part)? The white starts small on the bottom and then goes fatter. Mine is an 2004 V
You can see it in the middle of this pic, is there a light
https://www.google.com/search?q=2004...le%3B225%3B169
Here you go.
Look like you cant replace that light with out modding it. My light work something but I'm thing of replacing it with a 4mm LED.
The light is under the blue light condom.
Here the 12volt light. You can't replace it. I'm going to remove that light and replace it with a 4mm LED. I'm post more about it later today.
How to replace the Dimmer Light.
Parts:
5mm clear White LED NTE300045 $1.63
Resistor $.10
You will need to download a LED Resistor Calc or find one on the internet.
LED calculator:
11.8V Source voltage
4.5V LED voltage
30 diode forward current (mA)
You will need a 270 ohm resistor.
When I did the calculator I got 211 ohm resistor. The high the ohm resistor will make the LED less bright.
Here the part I got.
After removing the old Light. I had two hole to drop the new led in.
I solder the resistor on the positive side of the LED.
I slip the LED into the little hole and solder the back of the board.
Added some tape to the LED and slipped a straw around the LED wire to help hold it (I did not get a picture)
Negative and Positive
Low Dim.
High Dim.
Here a video showing the dimmer working.
Parts:
Resistor $.10
LED calculator:
4.5V LED voltage
Low Dim.
High Dim.
