Revshift Full Bushing Kit
Full bushing kits are now available for the 2004-2007 CTS-V and the 2003-2007 CTS.
Revshift polyurethane full bushing kit completely replaces the oem rubber bushings on the 2004-2007 Cadillac CTS-V. These bushings stiffen the vehicle's suspenstion significantly improving the vehicles handling capabilities.
-Improves handing
-Reduces wheel hop
-Will not wear out like oem bushings
-Properly dampens the suspension
-Lifetime warranty
The kit includes:
4x cradle bushings
4x rear upper control arm bushings
2x trailing arm bushings
1x differential bushing
4x front upper control arm bushings
4x front lower control arm bushings
8x Teflon prelube
https://www.revshift.com/shop/full-b...llac-cts-v.php
-Improves handing
-Reduces wheel hop
-Lifetime warranty
The kit includes:
4x cradle bushings
8x Teflon prelube
It's one of those skills that, sadly, you acquire and then never use again. I could do all of the bushings in a day, now that I understand how to dispose of/destroy the OEM bushings quickly. Sometimes I wish I could help people install their bushings, but then I realize what I'm saying and correct myself.
We still have some of our red bushings in stock. If you want red just give us a call and we will hook you up. If we don't have the red bushings in stock we can make them custom for you.
We are not planning on offering the 75D bushings on our website. If you really want a set then we can make them for you. They are a phone call away.
Revshift-
Will you guys work out a package deal that includes motor and trans mounts. EVERY bushing in my car is OEM rubber
It's one of those skills that, sadly, you acquire and then never use again. I could do all of the bushings in a day, now that I understand how to dispose of/destroy the OEM bushings quickly. Sometimes I wish I could help people install their bushings, but then I realize what I'm saying and correct myself. Air hammer and some heat usually worked in the past for me... It's loud and you'll want a vice... But it's effective.
Revshift, what made you guys do the color change on the 95A bushings and can this kit be put together with a mix of 95A and 80A bushings as well? This plus motor mounts/trans mount are on my next to purchas list.
If you call your order in or place an order then send us an email with which hardness you want for specific bushings we can customize your order. We could put a bunch of options on the website so that you could pick each hardness but we feel it would overly complicate things.
I look forward to doing business with you.
