Trailing Arms?
Trailing Arms?
What's the general consensus regarding BMR vs CS vs MAP? Also what do you get for your money? Any reason for a stock height CTS running Forgestar F14's to buy these. I've seen some claims of a reduction in wheel hop, I do have GForce axles and while that problem has mostly been solved some additional help wouldn't hurt.
I don't think trailing arms do a whole lot for wheel hop. Bmr arms are straight so you dont get any more clearance for wider rims/tires, I don't think you can buy new map arms anymore, so that leaves the cs arms which are well built and offer way more clearance than factory or bmr arms. I have heard of forgestars rubbing the factory trailing arms so cs would be a good option if you ask me. I have a set going on soon myself. As far as wheel hop reduction, I would invest in a set of revshift 95a cradle bushings if you don't already have them. I've got cradle bushings and gforce econo axles ready to install and I'm hoping to eliminate the majority of the hop that way. How noticeable/effective were the gforce axles in your experience?
InfrareV, I also agree that if you are trying to eliminate wheel hop that the cradle bushings are the best bang for the buck.
We, Creative Steel offer cradle bushings. Take a look at our site.
We also offer a tool that we designed especially for removing the original bushings from the CTS-V cradle. With out the tool the removal of the original bushings is a laborious, time consuming dirty job. The tool comes with 8-1/2 X 11" laminated photographs with the instructions printed on the them.
I bought both the left and right axles, they were quite effective. I think easily 90% of the hop is gone. If I'm honest I do have a little bit of buyers remorse only because I bought them before the CS 8.8 came out and I likely would have headed in that direction if I hadn't already made an investment in the stock diff.
Unless you need wheel clearance I would not worry about trailing arms. I run the BMRs on my car and couldn't tell a difference in handling either(even regularly Autoxing the car i didn't notice anything). Although I suppose once I get poly bushings in that it will all help to incrementally tighten things up (and maybe drop my times some even if i can't "feel" it)
I just recently installed the BMR trailing arms. I have them coupled with the Revshift 95A trailing arm bushings as well. Obviously, there aren't any clearance gains by switching to these, and the reduction in wheel hop (although noticeable) was negligible. The benefit though, is that the car felt more planted afterwards and actually felt like it hooked better on a hard launch.
Did you notice any more road noise after the install?
BMR, as far as I know, have only offered arms with QA1 spherical bushings. No added road noise, though I did have to shim them on the install as the spacers they provided weren't long enough.
I have Creative Steels trailing arms with spherical bushings and greaseable bolt/bushing. Well built, prefect fitment. I plan on trying to run a 11" wheel in back. We will see how much I can get there.
