Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Carbon Fiber intake tube?
Old 05-06-2014, 07:47 PM
RecklessV's Avatar
Saw a carbon fiber tube on ebay for $110 , dont know if thats considered cheap or not?
What filters are you guys running? I have a K&N, but Ive read a lot of bad things about it.
Old 05-06-2014, 08:35 PM
piening2150's Avatar
Originally Posted by steves ls6
I just need the dimensions.
My tube is 3.5" x 9". I had to cut it down. It was 10" or 12" originally. It was $25 shipped when I got it off ebay.
http://m.ebay.com/itm/281298778812?nav=SEARCH
I think this is who I bought mine from, may want to contact them to see if they have shorter lengths. Don't see any listed currently.
Old 05-07-2014, 01:28 AM
Naf
Naf's Avatar
LS1Tech 10 Year
I have the 4" CF tubing and its a pita. I have to admit i am squeezin more than the engine bay can handle now.
Old 05-07-2014, 01:39 AM
Goosecaddy05's Avatar
What radiator are you using? did it help with the temps at all? my stock one with 160 t stat wont keep it under 190 on a hot day unless its moving at least 60 mph
Old 05-07-2014, 02:29 AM
Naf
Naf's Avatar
LS1Tech 10 Year
Ron davis rad...
I also have a 160 stat but set to 180 stat settings not to cook the fan motors.
Once moving it drops, but other than that it held true to 180-185 which is fine.
I had one fan fail and i use to over temp very quickly in stop and go traffic, once i started to move it cooled off again....
Old 05-07-2014, 10:42 AM
steves ls6's Avatar
Pictures wont open for me.
Old 05-07-2014, 10:47 AM
Naf
Naf's Avatar
LS1Tech 10 Year
http://www.flickr.com/photos/69163769@N07/14125017192/in/photostream/
http://www.flickr.com/photos/69163769@N07/13941344527/in/photostream/
Old 05-07-2014, 12:39 PM
steves ls6's Avatar
http://www.flickr.com/photos/6916376...n/photostream/
you got a bad *** car
Old 05-07-2014, 03:36 PM
InfrareV's Avatar
Originally Posted by Becker
InfrareV - What and how did you tap into the silicone tube for the pcv vent tube on the LS2.
I just used some PCV fittings from the Dorman display and epoxied it. I don't have any P/N's.
Old 05-07-2014, 06:32 PM
'99REDTA's Avatar
I'm working on making a gto intake work with my rigged K&N enclosure, it has a 45 degree bend which helps get it over the bolt but I need another 45 coupler to finish it off... I think, it looks like it will work
Old 05-08-2014, 12:31 AM
Naf
Naf's Avatar
LS1Tech 10 Year
The GTO and camaro intakes are not going to work. the engine is further back than ours. You just need asection of straight tube, a 90 and 45 elbow, and a home made sheet and you have a CAI on a budget
Old 05-08-2014, 05:03 AM
  #32
ravenls6v's Avatar
I can't find cheap carbon tube anywhere, all I can find is expensive structural type stuff for around 100 bucks a piece.
Old 05-08-2014, 05:33 AM
  #33
Naf
Naf's Avatar
LS1Tech 10 Year
cant help you out there, i used all mine up...
Your gonna have to pay to get good quality CF...
You want cheap then buy ALU pipe
Old 05-08-2014, 06:11 AM
  #34
ravenls6v's Avatar
These guys are talking about paying $25 for a decent looking tube, I'm not trying to be cheap just don't want to pay 4 times that to achieve the same goal. I'll have to just watch ebay for a while.
Old 05-08-2014, 06:18 AM
  #35
Naf
Naf's Avatar
LS1Tech 10 Year
I paid $250 for 26" length of 4" CF tubing. I then made Alu ends so when i clamp down it doesnt break the CF. Then i finished it off with Nylon Locks so it will hold tight and not look tacky...
Old 05-08-2014, 07:08 AM
  #36
ravenls6v's Avatar
Naf, I see the thickness of the cf varies with price....what's the ballpark thickness of the tube you used? I don't want to over/under do it if I can help it.
Old 05-08-2014, 07:42 AM
  #37
Naf
Naf's Avatar
LS1Tech 10 Year
1-1.5mm is more than plenty. Mine are 1.5mm and i still added the alu rings on the outside
Old 05-08-2014, 12:44 PM
  #38
lollygagger8's Avatar
Drill a hole, thread/screw in a barb fitting that fits the hose you want to use, RTV the threads of said barb fitting. Done.
I know mine is the plastic intake, but you can do the same to silicone
Old 05-08-2014, 02:35 PM
  #39
ls1247's Avatar
it wasn't that clean when it was new...damn
Old 05-09-2014, 01:08 AM
  #40
Naf
Naf's Avatar
LS1Tech 10 Year
U can also pop a hole in the silicone hose after the maf
Quick Reply: Carbon Fiber intake tube?
