Hemi hellcat smokin' a cts-v video
#42
So, since watching this video, ive become more and more obsessed with being able to keep up with these shedevils on the road (as unachievable as that may be)
After talking to TTP last week about LS3 Swaps and labor pricing, then some search on the forums and interwebs, I came up with three of the following scenarios for my car. Only one gets anywhere near hellcat numbers and have the potential to equal.
Please see attached screenshot I took of an excel I created. Main thing to keep in mind in this, is if it is a blower scenario, I would be installing that so you will not see Supercharger install labor
Things to Note
I have a 4th Gen rear already - to be installed (Labor listed)
LS6 Blower Scenario refers to the Maggie
LS3 Blower Scenario refers to this Monster, linked below
http://www.westcoastcorvette.com/p-1...YZ0aArP68P8HAQ
Let me know if anything is blatantly wrong or missing from my estimates
Thanks
Things to Note
Thanks
#43
Tune will likely run more if they do it right. You will need fuel system upgrades (didn't see them).
Personally I would go with the Eforce for hood clearance reasons and known quantity. Also, with heads and cam you should be able to do more than 600hp. I don't want to start a war but IMO flow enhancement works on the FI motors to.
#44
Blatantly wrong It won't hold. Get the 8.8".
Re:Tune Pricing - what they told me, IIRC it would be a discounted rate for doing all the other work w them.
Re:Heads and Cams - Just being conservative on numbers, but keep in mind, these are WHP numbers, not at the motor.
Re:Fueling - I think the ls6 can support 500 whp on stock fueling? I'll have to dig more into that, Also, the SC kit for the LS3 comes with everything to make it bolt on and work, so Fueling is accounted for there in that scenario
#45
"So, since watching this video, ive become more and more obsessed with being able to keep up with these shedevils on the road (as unachievable as that may be)" - Quote from member Negligence
Have to admire his willingness/ eagerness and game plan in order to pursue what he calls the "shedevils " in reference to the Hemi Hellcat !
#46
Was thinking the same thing as you but then someone said don't be too quick to judge and check out the video and see what the Hellcat does to a CTS-V wagon on a road course.
The Hellcat's fury at Grattan Raceway MI - YouTube
I'm a road course guy and while I'm no pro, that guy in the V wagon was all over the place.
#49
Re:Rear - Totally right, was thinking about posting an edit for that. Do you think the 4th gen wont last tuning and highway usage though?
FOr the tune to be done correctly you will need to scale MAF and injectors which takes a while. My tuner charged $500 but it was absolute garbage. So much so that I tuned it myself. Much better now.
Yup. My comments were based upon WHP. The only reason you wouldn't get there would be the IAT2 you might see with that blower. Two LS7s running those here are seeing +70 degrees over ambient with HUGE coolant reservoirs. I am not sure why.
Does the kit come with a fuel pump or just a boost a pump. If the later then I would go with a new FP as well.
Good luck
#50
4th gen should last through tuning - mine did.
Good luck
Good luck
Re:Fueling - Its a fuel pump booster, so adding Fuel Pump to the list would be a must. Did you have any thoughts on my "Misc parts" budget - I think FP would fall into that, and do you think i need to increase that number as well?
I have quite a bit of funds saved for this now, but depending on which scenario i go with, I may need to do quite a few of the steps at once, hence needing to save more. Although im sure I could get the ls3 in there and drive it like that for a bit, before taking the next dive with the blower setup and add on all those supporting mods. At least then it will give me time to use my 4th gen rear with a little piece of mind, and when I make the SC Dive, can beef up the rear to the 8.8 and 4.1 Gears....then its shedevil hunting time
#51
i think it all depends on the car in question whether or not one car will be faster... people are saying it will take 650rwhp v2 to match a hellcat but i've embarrased a v2 auto with 650rwhp in my n/a 500whp gen 1 v... so its all relative
#52
Apparently the Hellcat was being driven by the SRT division head Ralph Gilles who was savvy enough to use this vid to show the handling ability of the Hellcat on a road course as it specifically chases down the CTS-V wagon (which as everyone knows is noted for its handling ), "shitty driver" or not.
IMO, a shrewd move on their part.
#53
Noticed there is a guy on the CTS-V owners forum who is selling his 2011 auto CTS-V with 730 RWHP( best of 10.77 @ 127 mph ) for $ 35 K and is replacing it with a Hellcat.
Interesting to note there is less than a 1/10 of a second difference and a 1 mph difference between this guys 730 RWHP CTS-V and the Hellcat's 10.85 @126 reported best time in the 1/4.
Based on these numbers not sure if 650 rwhp for the V will be enough.
#54
#56
Here's the mod list straight from his sig:
2011 Sedan Black - CAI, Ported TB, Snout and Blower, upper and lower pulley, cam, dual springs with titanium retainers, injectors, thermostat, heat exchanger, kooks headers and xpipe, engine and tranny tune. 631 rwhp
Best 60ft 1.57
Best ET 10.77
Best MPH 127.60
#57
Had to chime in to correct this. BuddyG's CTS-V ran that time with 631rwhp not 730rwhp.
Best 60ft 1.57
Best ET 10.77
Best MPH 127.60
Best 60ft 1.57
Best ET 10.77
Best MPH 127.60
You're right. Could have sworn I saw the 730 number listed for this car on another thread on that forum.
The 630 rwhp certainly correlates with his ET and MPH.
After looking at the " buddyg" thread on that forum again here's something that could be interesting. Apparently he wants someone to drive his 631 rwhp CTS-V so he can match race it from a roll against his new Hellcat.
#58
I would love to see how the Hellcat engineers dealt with IAT's over the long term. A twin lysholm (Whipple and Kenne Bell) build huge amounts of heat by design. One lap on a course may be manageable, however I don't see any plausible strategies where IAT's would not reach critical levels under continued operation.
I see the Hellcat being more of the old '03-'04 Cobra's with a Kenne Bell, a nice drag or roll race car until about the third pull and then it's done.
#59
Seems to me I read where the engineers goal with the IAT's was to achieve zero degrees of timing pull back for at least 20 minutes on a race course in 100 degree heat and to that end they were apparently successful.
#60
I'd love to see a Hellcat run a ZL1 or a V on a road course. I believe that's where the Hellcat would show its true weaknesses.
