SOS...06 cts-v not starting
I have checked and double checked every fuse and relay under the hood and rear seat with a multimeter.
According to the book, if you get 12 volts at the keyswitch, you should be able to turn it to the on/accessory position and see 12 volts at the brown wire, unless you burnt up the switch or another reason.
I would like to know if the 12 you are seeing on the switch input goes away when you turn the key to on/accessory.
That might indicate a short in a dim or rim module.
I hope your repair isn't expensive.
OK......soooooooo.......A ******* FUSE!!!!!!!!!!!!!!!!!!!!!!!!!!
My dumbass thought that i could just check for continuity on all fuses, which all checked out fine. But no, damn fuse on the rear passanger side was bad, replaced, and now the V is alive again.
THANK YOU ALL!!!!!!!!!!!!!!!!!!!!!!!!!!!!
EXCUSE MY DAMN STUPIDITY....lesson learned.
thank you...come again.
/thread.
/thread.
I was checking for continuity, not voltage on each side of the fuse. I learned my lesson. Now i know to check for voltage on each side every time im checking fuses, not just continuity.
#33
I have seen fuses look visibly fine, but have no continuity and are bad. Never the other way around haha
#34
can you be specific to what fuse it was? i am having a similar issue. was intermittent at first and today i went to start the car and let it run as its not a DD and i get no luck. not even wanting to turn over. i wiggled the relays under the hood but didnt have time to start replacing **** yet.
