Meth or Corn, the debate continues....
It makes a hell of a lot more sense, pm leanpocket.
Why is your milage cut so far down?
Yes you are using FI and yes you have other upgrades, but at 2000rpm you are not at full boost nor will you be at the edge of performance.
I feel your tune is too rich and needs a tweak, with performance also come efficiency. The more efficient you make your engine the more power you get out of her...
Also get some microlon and treat your engine as well as your drivetrain, it will give you 25% plus on your milage
16mpg and 17 gallons=272 miles. That's what I average. Could I stretch that further? Sure. But with what fun? Get your car up and running and tuned and put three tanks through it then report back on what avg mpg you're getting. I had one of the best in the business tune my car.
Just waitin on my ecu and then i will start to do as you commanded.
My tahoe gets about the same milage as you. Which for metric ppl is about 14.7ltr/100km
In order to get 400mi out of your tank you have to get it better than 23mpg. Thats a tall order.
Why not add snow performance's mpg kit? I have it on my tahoe and its great, brings my iat from 52c all the way down to 24c. Thats 127f down to 75f thats real numbers and only on a 5.3ltr engine. Added bonus is when you are acceleratin above cruisin speed it helps boost your octane charge and cool your air charge...
#32
I'm late to the party here but go E85 and never think twice. If it ever becomes unavailable here I will no longer modify cars.
That said, my mileage sucks bad. With a huge pump, 85% ethanol and 2250cc injectors I average around 7mpg. But that's an extreme case I think haha
#34
Wait, break that down Barney style for me. What will I have to do in order to run the corn?
Would an 06-07 OS be plug and play? I'm sure the reluctor and knock sensors would be an issue. I have done zero research on this so far so I apologize for asking to be spoon fed!
I pmed lean pocket and am waiting for a reply. Past that I have learned the A1000 pump will likely not meet my needs. And the Weldon pump taking its place is $$$
#35
no, 04-05 van,truck and suv OS is what you need. same pcm you have now.
why spend big $$ on a pump that is super noisy and probably more then you need anyway\
i have twin 044s and plenty of fuel, im sure that would be cheaper and last longer then a big single
#36
#37
As for the fuel pump I'm going by what Lonnie recommended I do. I mean, he is the fueling guru right?
I would be curious to know more about your fuel system though. I have seen the cell when you sent me pictures but never really asked for too many details.
The pump isn't all that bad and I nailed down that im going with the Weldon DB2025-A pump at 760$ so what, 260$ more than the A1000 for a way better quality pump?
Another problem I have is the fuel cell. I can't really go with like the setup you have as I need a cell that is SCCA approved. Which adds serious $ to the equation.
