Carb Spacer
Carb Spacer
How much of a gain is a spacer really worth? I am reading mixed reviews online, I figure since I am running an open port intake design, I should buy an open port spacer? Any advice?
My set up:
LQ9 408
12:1 Compression
L92 heads ported/polished/valve work
Victor Jr Intake ported to match heads
TSP 251/259 66x/66x/ 114+3
MSD Ignition (6010) thru truck coilpacks
Built TH350 w/ stall appropriate for nitrous
Nitrous at a later date.
All in a sub 2900lb notch mustang.
My set up:
LQ9 408
12:1 Compression
[QUOTE=ZONES89RS;13903019]Increasing high end velocity usually helps, a thicker spacer would be key, the only way to tell is to run a couple back to back trials with and without, different setups respond differently.[/QUOTE
I had dyno proven the difference tonight the difference of no spacer and the 2in. cnc'd HVH spacer. With out a doubt best money spent on the spacer low end power and tq increased for approx 3000rpm's by 30hp and 21tq to the wheels!
there are actually various versions of it. and even made from phenolic plastic material. can buy them at jegs, ebay, etc.
I would like to see those dyno sheets because that sounds like an incredible amount of increase. If this is in fact the case the manifold was way too small in the plenum to start. I would not expect these kind of gains on every engine. What is your engine/application?
Stock LS1 346ci. from 2002 Camaro SS
New bearings and rings
ARP Rod bolts
ARP Head Studs
Vic JR. Intake, Cleaned the runners up
853 heads that have been extensively ported intake and exahust runnners, bowls everything, 5 angle valve job, milled 0.040
had to fly cut the pistons to clear the cam
Thunder Racing' T-Rex cam
SLP 25% underiven pulley
Comp Cam push rods
Patriot GOld Spring kit set up for the cam
Truck coils
Autolite plug wires
NGK TR6's gapped at 0.050
The shortie headers
H3 oil pan
nitrous converter
TH400
big drive shaft with the 1350's
ford 9in with spool and 5.13's
moser axles
MT DR's 275/60/15's on weld pro stars
oh and a 2in. HVH spacer now..lol
